Flex Cable/solder
  • Wetter
    • Aug 2013
    • 241
    Flex Cable/solder
    how much heat can a flex cable take when soldering motor end coupling side?
    i am thinking of brazing with (refrigerant silver solder) just curious on if it would weaken the flex cable drive under map gas heat?
    hey i am thinking not but i still would like to here if possible or not.
    Thanx.
  • Doug Smock
    Moderator
    • 5272
    I use 45% on all my cables from .130 to .250 without issues.
    Some of my .250 cables I use set screw couplers and braze 5/8"of the end of the cables. MAPP or propane will get the job done. If you use oxy acetylene make sure you use a neutral flame.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Wetter
      • Aug 2013
      • 241
      yes, thank you Mr. Smock i down loaded info off OSE but no mention of this.
      Once again Thank You kindly. I just thought regular solder was too soft.
      also on Wohlts site they mention 55% Brazing with their product.
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Get it too hot and you blow out the brazing then not as strong. I have had a few failures and this was one of the reasons.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • Wetter
          • Aug 2013
          • 241
          yes i found that out yesterday
          prop shaft i used Loctite 638 but the motor coupling side i tried some brazing rod i use for a/c copper line set, got way too hot.
          any way try try again and gave soldering iron a chance but with 3% wire solder so far so good.
          • Doug Smock
            Moderator
            • 5272
            Sil-fos, as you found out won't work.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • rickwess
              • Apr 2013
              • 777
              Sorry, what is sil-fos?
              I have 3% silver, electrical and plumbing solder. Which one is best. I'm also a short drive from Sayal if it's something else.
              • Doug Smock
                Moderator
                • 5272
                Sil-fos
                United Refrigeration is one of the largest wholesale distributors of HVACR equipment, parts, & supplies. Trusted among contractors, supermarkets, mechanics, & more to provide prompt, comprehensive service & focus on our customer's individual needs.
                45% silver http://www.uri.com/is-bin/INTERSHOP....F&OnlineFlag=1
                Flux for the 45 http://www.uri.com/is-bin/INTERSHOP....F&OnlineFlag=1
                If you are having success with the 3% use it.
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • rickwess
                  • Apr 2013
                  • 777
                  I haven't tried anything yet. I will shortly just want to know what I'm getting myself into. What is generally recommended for soldering the flex cable?
                  • Doug Smock
                    Moderator
                    • 5272
                    I have used the 45% since I've been playing with boats. Ed Hughey, Speedmaster, etc cables all have the stubs brazed on with a brazing alloy with a high silver content.
                    Some guys........http://forums.offshoreelectrics.com/...ng+flex+cables
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • rickwess
                      • Apr 2013
                      • 777
                      Thanks.
                      What that tells me is I should get an extra long flex cable and experiment/practice. I'm thinking that if I can solder 8awg wire with my soldering iron set-up, I should probably be able to solder a flex cable. Like any good soldering, I'm sure the secret is to use acid based flux and not rely on the flux in the solder core. Worse case is to break out the micro torch to get a little more heat.
                      • Wetter
                        • Aug 2013
                        • 241
                        the flex i soldered was for my tug, but when i go to do my FE's i want somethn' more substantial.
                        thanx again.
                        ps
                        Do not use acid flux, which it can wick up into cable and cause rust and or corrosion.
                        • rickwess
                          • Apr 2013
                          • 777
                          My assumption is that soldering the end of the flex cable is to stop it from fraying from the repeated insertions into the collet. When the flex cable is under load, the direction of rotation actually tightens the winds, hence the gap we leave between the drive dog and whatever we use.
                          A good clean with alcohol, then your grease should prevent any rusting after that.
                          • tlandauer
                            • 5666
                            Most of my cables are not soldered ( collet end). The alignment on them are pretty good, when I insert the end into the collet, I turn the cable ( prop) clockwise as I push, never had a frayed strand of steel wire. It's also important that the end is not bluntly cut but chamfered.
                            • Wetter
                              • Aug 2013
                              • 241
                              ok, chamfered,
                              by filing or just an angle (bevel) cut?
