I searched for suggestions to this problem and could not find a thing but that actually makes sense because this an odd problem....
Over the past few years I've installed plenty of water jackets on boat motors and as you all know its not a very difficult thing to do. However while sliding a new leopard water jacket on to some brand new 4092s the O-rings shredded when forced onto the motor. These particular O-rings seem to be too large (cross section wise) and seem to be a bit too large in diameter. OR the water jacket is a tiny little bit too small in diameter. The o-rings easily slide over the motor by themselves, but when you stuff them into the jacket grooves (And that is a real trick to do as well) they shred every time.
I've tried lots of oil and even tried marine grease bit they still tear up when they are forced on. It takes a whole lot of pushing for that to even happen. I bought a bag of new O-rings for this motor from OSE and still...shredded. The front CNC cover of the 4092 has small screw wells so the screws will be flush. These little wells have some pretty sharp corners so I dulled them down with a dremel tool and a sanding drum and the O-rings STILL tear up.
I'm out of ideas. AAAHHH!!!! If I can't find a better solution, could I just use them (all messed up) then seal all the way around with silicone? How would silicone stand up to that kind of potential heat? Is there another sealant out there that would work besides something super permanent like JB Weld?
Do you guys know of any other tricks that would work in this situation? Anyone had this problem before? Would another brand of water jacket or o-ring fit better than a leopard water jacket?
