Delta Force Size of 21MKII : 920MM (37")
  • lenny
    • Sep 2010
    • 4294
    Hi,
    Any one running this size DF 21MKII at 37"?
    http://forums.offshoreelectrics.com/...ware-installed
    I have this one, But it is not setup yet to run.
    And I was looking for some info on how they handle before I try to set this one up.
    Thanks for any info.
    ? ONLY IF THEY WORK
  • lenny
    • Sep 2010
    • 4294
    Hello is there anybody out there,
    No one has any info about these hulls or close to it ?
    ? ONLY IF THEY WORK
    • kievyu
      • Jun 2011
      • 23
      for fun ... 5692kv1300 + 6S2p li-po + 180a ESC + X450/3 around 50mph.
      • Scott T
        • Oct 2007
        • 590
        Great hull, handles really nice. I raced mine on 6S and 4S and won a heap of races. I did a build thread, search for my started threads at my profile, I only have my phone here, so hard to paste a link.
        Scott Tapsall
        Pine Rivers Model Powerboat Club - Facebook Page
        My Gallery
        • Jeff
          • 232
          What 4S class did you run a 37 inch boat in?
          I try and avoid paste eaters.
          • lenny
            • Sep 2010
            • 4294
            Hey Scott.
            Thank you very much for the heads up on where to look for the build and info on the hull,
            I tried a few search on hear and yahoo to but could not fine much info.
            I love what you did on your boat,
            And that easy in and out motor mount.
            http://forums.offshoreelectrics.com/...ott-s-DF21-Mk2
            That build of yours was when I just got started into FE and hooked by my Rio ep modding.
            With yours and the flooded stuffing box,
            Did you find that you needed all that adjustment that was there ?
            As you can see the one I have already has a stinger mounted on it,
            But it could be modded in to a flooded tube I guess.
            I will be using it for sport running and have a few motors laying a round that may fit the build.
            What do you think about any of these motors for the hull ?
            Hear a couple motors on hand for 4s and 6s setups and using a Seaking 180a ecs if it will handle the hull,
            For 6s setups a Acr 3675 1680kv, CC 1520 1600kv, T600 1400KV, Atomik V700 1100KV And also a LP 5698 910kv,
            And for a 4s setup not to sure what will push it nice,
            I have a LP Nemesis gold 4082 2200kv or a TP 4050 2200KV, also a couple of FC 3126 1600kv,2200kv and a T500 1800kv.
            Boy I have a lot of sh$t laying around.
            Also some other 36mm can motors.
            ? ONLY IF THEY WORK
            • rickwess
              • Apr 2013
              • 777
              I noticed that as well. The best rail motor mount I've seen. I predict Steve will need to get more DF's in stock with the rails installed.
              • Scott T
                • Oct 2007
                • 590
                Jeff, EA Mono here in Australia. We limit batteries, not hull lengths.
                Lenny, I didn't need much adjustment, just set the strut/stinger level and play with the height a bit. I don't know too many of the motors you listed, but the CC 1520 on 5S would be good (or 6S would be OK if you are careful with prop selection). I probably wouldn't run it on 4S for sport running, I only really ran it as an experiment and needs a strong motor. It is better on 6S.
                Scott Tapsall
                My Gallery
