thoghts on hk pursuit
  • pugman2
    • 236
    ok im still looking at buying one of these i know i will have to change motor cause everyone says stock is trash thinking lepeard 4082 and 2 4cell 6500mah not sure on discharge rate 25-30 not sure thinking 180 esc wich would allow me a wide rang of batterys i think . been watching for a used one in my buget but dont see many used and abused pursuits gonna have to sell my sv27 first prolly
  • martin
    • 2887
    Min discharge for boat use 40c, better still 65c.
    • TheShaughnessy
      • 1431
      Be patient one will come up. That's how I got mine. Spent close to 2 months looking.
      • pugman2
        • 236
        i have 2 cel 5000mah turnagys i think 25-40 discharge would they be to small
        • pugman2
          • 236
          next dumb question if i get a high discharge rate it will only use what it needs right. to big is better than to small as long as esc is rated for it?
          • TheShaughnessy
            • 1431
            For a 4074 I would use more battery yes . Those packs will work but it will be hard on them.
            • pugman2
              • 236
              was looking at the 4082 motor 1600kv and 180esc
              • lenny
                • Sep 2010
                • 4294
                Hi,
                From what I have read on hear the stock motor is a pretty good motor.
                And should be fine on 4s and 5s if not over propped on the setup.
                And yes the 180a esc will do the job well,
                As for cells 4s or 5s 40c 5000 turnigy should handle most setups for that hull.
                I would just run the stock motor with a 180a turnigy esc and up grade the flex shaft to a .187,
                And try the 2s 25c to 40c 5000mah cells you have and see how it run like that.
                ? ONLY IF THEY WORK
