I have a virgin Pursuit hull on the shelf which has been there for a couple of years. I recently purchased a ARTR tunnel hull outboard setup from HK and really like this outboard stuff. That being said I do have a spare outboard, and everything else required to set this up. Problem is I need to know at what height do I install the prop shaft in relationship to the hull? Should I install trim tabs? Turn fins?
Although the hull is longer the weight is nearly the same when I compare the 2 boats do you think this will work? That being said I hope the hull efficiency is not that far apart to allow me to actually get up and out with the Pursuit with this rather small outboard.
Can someone point me in the right direction for determining CG when installing batteries on this.
