i can't figure this out and need help
  • drtlvr
    • Jul 2013
    • 8
    i'm trying to set up a hobbyking 120A boat esc, of coarse it did not come with instructions and somehow in the process of trying to get it set up ,I had my esc plugged into the steering port instead of the throttle now my throttle works when i use the steering and i can't figure out how to reprogram it,i tried to do the whole start up procedure but i get no beeps or anything, I'm new to electric as i come from a gas background so this is all new. please help me
  • martin
    • 2887
    Go to the HK page of the particular esc, part way down the page just above the customer reviews click on the purple box marked files & you can down load the instructions.
    • drtlvr
      • Jul 2013
      • 8
      tried that, if i plug the esc into the throttle port on the receiver and then follow the instructions, I get nothing no beeps nothing, if I plug the esc into the steering port I get beeps and can turn the motor on, I know the throttle side port works because i can control a servo from that side, maybe i should try a different receiver and controller? i'm lost
      • lenny
        • Sep 2010
        • 4294
        What tx&rx and what esc are you using ?
        Have any links for them ?
        Also did you try calibrating the tx to the esc first ?
        Than do the program setting for the esc.
        ? ONLY IF THEY WORK
        • Mike Caruso
          • May 2012
          • 940
          Nice runs Lenny.
          Do It Like You Mean It .....or Don't Bother
          • drtlvr
            • Jul 2013
            • 8
            Have any kinks for them ?
            tx - tower hobbies astro gx202
            rx- tower 2 channel gxr202
            esc hobbyking 120A boat esc
            i tried to calibrate with the plug in the throttle port of the rx but it will not respond but a servo works in that port, if i plug the esc into the steering port it works but that is backwards i need to find out how to start all over as if i never plugged anything in.
            • drtlvr
              • Jul 2013
              • 8
              and what did you mean
              by kinks?
              • lenny
                • Sep 2010
                • 4294
                Do you mean my video's Mike ?
                If so thanks,
                I will be shooting some more of the pursuit testing on 6s again tomorrow.
                So far it is running nice and temp are very good and run times to.
                Originally posted by Mike Caruso
                Nice runs Lenny.
                ? ONLY IF THEY WORK
                • lenny
                  • Sep 2010
                  • 4294
                  Sorry I meant links to your stuff.
                  Try taking the battery's out of the tx to start over,
                  May be that will work.
                  Than you may have to try a rebind to rx to tx,
                  Than calibration of the tx to esc than do the programing again.
                  by kinks?
                  ? ONLY IF THEY WORK
                  • drtlvr
                    • Jul 2013
                    • 8
                    ok ill try that tomorrow, i'm giving up for tonight
                    thanks
                    • siberianhusky
                      • Dec 2009
                      • 2187
                      Which HK 120 amp esc? Turnigy, Aquastar, HobbyKing, Birdie, Hobbyking SS.... they have a few 120 amp escs! Each works/arms differently. Some need the throttle channel reversed, some need extreme trim settings to get them to arm.
                      Lots of good info given but it won't be of any use if you are using a different ESC than people think. Most are assuming the Turnigy 120 I think, good esc.
                      When you have it plugged into the steering port does the rudder servo work if it's plugged into the throttle port at the same time?
                      Just did a search on your radio! WOW! Antique! I've got an Aquacraft AM pistol radio and rx I'd send you for the cost of shipping, still old technology but a little more modern. I'm not sure if it's actually legal to operate your radio anymore, not that the RC cops will find you....
                      Send me a PM if you want that radio, shouldn't be much to ship. Used it until I got a 2.4 radio 3 years ago, just sitting on a shelf....
                      • drtlvr
                        • Jul 2013
                        • 8
                        it is a hobby king esc, I ended up finding another rx and radio just like the one i was using, i know its an antique..lol and this on seems to work, now if i can just figure out what all the beeps mean , would switching the rx and radio make it any easier to set up?
                        • lenny
                          • Sep 2010
                          • 4294
                          Post a link to the esc you have.
                          Also post some pictures of the boat and the setup that you have in the boat.
                          ? ONLY IF THEY WORK
                          • drtlvr
                            • Jul 2013
                            • 8
                            http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
                            i'll take some pics of the boat set up
                            • drtlvr
                              • Jul 2013
                              • 8
