Does anybody here use a proboat retrieval duck?
  • shartinspartin
    • Aug 2013
    • 257
    I was thinking about getting one but thought it was kinda pricey. Does anybody here use one to recover a flipped or broken boat?
    Thanks
  • lenny
    • Sep 2010
    • 4294
    Some member on hear have used them.
    But I think you would be better off with a cheap used kayak,
    Or just a blow up raft.
    ? ONLY IF THEY WORK
    • gsbuickman
      • Jul 2011
      • 1292
      You can achieve the same thing by making your own towable hook buoy rather than buying a duck. Make your hook buoy from a piece of pool noodle with wire tow hooks that run thru the center of the noodle. Attach the buoy with a length of good fishing line with snap swivels on it. You may have to attach a threaded eyelet or tow boom to the back of your tow boat, so you don't snag up in the prop. The duck uses a steerable jet pump but its small....
      • kevinpratt823
        • Aug 2012
        • 1361
        Don't waste your money on the duck. I had one, it is slow as can be, terrible if even remotely choppy, can barely get out of it's own way even without towing a boat.
        My private off road rc track
        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
        • shartinspartin
          • Aug 2013
          • 257
          Is that how you retrieve your boats?
          What kind of boat should I use to do this then?
          • Wetter
            • Aug 2013
            • 241
            i made a giant "H" of PVC conformed to my Atlantic Tug (agua craft) with pipe insulation, most awesome.
            depending on the craft I am retrieving i can make it any size up front.
            • JLShip
              • Jul 2013
              • 74
              Only problem ,can't get into one of those anymore, to many back surgery's. I'm building a Atlantic Tug (Aqua craft)
              ? Will the stock ESC and motor work? , can't see changing until one goes.
              RC Grandpa
              NAMBA Dist. 9
              Folsom R/C Modeleers
              • gsbuickman
                • Jul 2011
                • 1292
                Here ya go. The latest boat retrieval thread .....http://forums.offshoreelectrics.com/...boat-retreival
                • kevinpratt823
                  • Aug 2012
                  • 1361
                  You may want to consider that when it does go, you will now have 2 boats to retrieve, been there.(but not with the tug)
                  • siberianhusky
                    • Dec 2009
                    • 2187
                    IMO the retrieval boat should be the most reliable one! I like the good old armstrong powered canoe. Only thing to go up in smoke is the paddler....
                    • lenny
                      • Sep 2010
                      • 4294
                      How about the ones that you sit on top of and not in them,
                      Like this kind.
                      ? ONLY IF THEY WORK
                      • gsbuickman
                        • Jul 2011
                        • 1292
                        I was just checking out the insane boats site, most o those guys have an eyelet or a ow boom on their tow rigs ( primarily AQ Hammers ). they have a fishing pole hooked to the eyelet\boom via snap swivel. they run the boat out and do an arc aroud the stranded boat & back to shore. then they reel in the stranded boat.
                        anybody else do this ....
                        • lenny
                          • Sep 2010
                          • 4294
                          I just walk out to it,
                          Or I use a fishing pole or a blow up raft when the water gets to cold.
                          ? ONLY IF THEY WORK
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            I had the duck. Complete piece of crap
                            • chief3452
                              • Feb 2009
                              • 39
                              Yes, I do. I have a floating snare made out of pvc wrapped in pool noodle similar to a ski rope handle attached to a fishing line. I run it out piggy backed on my Villain around the dead boat, pull it off the back and reel in. Works every time. If the dead boat is fairly close to shore, usually less than 30 feet or so, I just sideways cast the snare out over the dead boat.
