Ok so my Mystic keeps melting the solder on the blue wire to the motor. I have done multiple things to try and fix the problem with no luck. So my next step is try a different motor. I have a spare motor but its a 2000kv from one of my Genesis cats. My question is on the stock 60amp ESC is this motor going to be too much for it and is it going to burn up my esc.
Having some issues with my Mystic 29
Tags: None
If it is always the same wire did you resolder both connectors (motor and ESC).
Note, I run a ul1 2030kv with the AQ60amp ESC no problem. Just make sure your setup is not running wet or overpropped.
Chief
Sent from my XT890 using Tapatalk 2Comment
Thanks guys. No Chief it has always run dry in the hull I can say that it is very good about that. im going to try this other motor and see what happens. Ya chief it was always the blue wire and I resoldered it three times.Comment
Well run update. I ran it with the new 2000kv motor installed and so far no issues. I checked the temps in everything every couple laps and everything felt good. planning on doing a little long set of laps between checks just to make sure it's not hurting anything. But it seems like the old Proboat motor was the culprit.Comment
