Bearing lube?
  • HTVboats
    • Jun 2011
    • 803
    Bearing lube?
    Since I run outboards and they get wet more than I'd like, I use a lot of WD40 and Corrosion X. Using an air hose first and after I wonder if I am driving lube in and out of the bearings. I relube my bearings often. I have been using "Lightning lube" from Boca. Anyone have any secret formula or bearing oils you would recommend?
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
  • Bduncan
    • Jan 2013
    • 296
    I imagine boca gives good advice on what to use.
    • HTVboats
      • Jun 2011
      • 803
      Boca recommends their lube. At $10 for 12cc's. Looking for cheaper alternative that may even be a better lube?
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
      • Bduncan
        • Jan 2013
        • 296
        • Kris Flynn
          #2 Bench Racer
          • 229
          Outboard gear oil Mic, good for shafts and bearings!
          I flush motor out twice with metholated spirits and oil bearings with gear oil!
          We need to have a chat about our adventure!!
          • SirBudman32
            • Aug 2011
            • 625
            I use Boca oil now, But when I first started in Rc Boats I was using sewing machine oil for my bearings and it works pretty good and cheap.
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • Johnnysplits
              • Jun 2012
              • 45
              In my testing, Acer Racing sin lube works better than Boca's. It has less drag.
              • jcald2000
                • May 2008
                • 774
                I use syn. automotive differential lube 75-85 weight. E/T shows NO rpm change.
                • HTVboats
                  • Jun 2011
                  • 803
                  Gear lubes. hmmm. Back in the day racing full size outboards we often used ATF in our gear cases as it was less drag than gear oils. I think synthetics are a positive. We need an oil that will penetrate seals and stay on the bearings. Moly lubes like STP stick but don't penetrate easily. Any other ideas or discussions welcome.
                  Mic Halbrehder
                  IMPBA 8656
                  NAMBA 1414
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    This is the one I use. It is light enough to weep past the seals in the bearings. Plus it displaces moisture. I also drip it on the thrust bearings & the rudder hinge pins.
                    There are many equivalent 3 in 1 oils made by oil companies. Your local auto parts store would have some too.
                    • tlandauer
                      • 5666
                      Mobil 1 10W-30.
                      It really is not that thick, penetration is good, lasts for the run, I have so much of it from my garage. I put it in a small eye drop bottle with a long metal "needle".http://www.rockler.com/product.cfm?p...4&site=ROCKLER
                      • ray schrauwen
                        • 9475
                        I use Scorpion outrunner bearing lube: Scorpion
                        Nortavlag Bulc
                        • Bduncan
                          • Jan 2013
                          • 296
                          Honda makes some really good
                          Synthetic transmission oils we use in motocross. Some guys run the 90wt in both tranny and the crank. May not apply but worth looking into
                          • tlandauer
                            • 5666
                            I like it, because it is plastic compatible, I have cracked plastic parts on my RC cars because of bearing oil. I bought BACHMANN's E-ZLube, plastic safe. But I like this better. Thanks!
                            • tlandauer
                              • 5666
                              I use Sta-Lube's HEAVY DUTY_HYPOID SAE 85W140 Limited-Slip Gear Oil on some of my strut bearings where it is submerged in the water . I lube the flex cable with Grim-Racer Speed Grease and a few drops of this in the strut bearings, especially like TenShock's strut has ball bearings, I feel the grease doesn't penetrate and this heavy gear oil can last at least one run. I lube very often.
                              How is the Honda stuff? I am interested, can one buy it at a dealer?
                              P.S. I know I am drifting away...but
