how to mount a screw in the glasfiberhull when the threads is broken?
  • waterproof
    • Jul 2013
    • 239
    Hello everyone :)
    I have just dismantled a new Kyosho boat and one of the "wood screw" that sits at the bottom rear of the hull on the trimtab and it will not get stuck, threads had gone before i got tightened the screw so it has came this way from the factory. It looks like its treads on the fiberglas hull.
    The question is how to get the screw in the hull without it loosens and falls out when threads are broken? This screew are small and sharp and just screwed right into the hull without nut to the other side, I took a power glue on the threads and i took power glue on the back of the screw inside the hull. Its one of the 3 screew to the right on the first pics
    Is there is a better way to make it sure it stucked while driving?
    Dont want it to fall out so i get water inside the boat.
    Should i just trust at the Power glue holds up or should i try to find a new bigger screew to mount? Or maby find a machinetreads screew and use nut to the backside?
    I have also glue every screew from the inside tp not get any water in so you know why its so much glue inside :)
    Can anyone come with a solution? :)
  • SirBudman32
    • Aug 2011
    • 625
    You could try a bigger screw or get some 4-40 nut and bolts and replace all the screws.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    • iridebikes247
      • Dec 2011
      • 1449
      I would just put a nut on the end of it. if one stripped out chances are the rest will too eventually so I'd do some replacing if you have the time.
      • waterproof
        • Jul 2013
        • 239
        I tryed to add treadlocker "locktight" now but im not sure because i have reed that a treadlocker is not god for plastic material.
        Hoped to get the boat on the water tomorrow so i will be thankfull for answers, im going to edit the tread a bit
        • waterproof
          • Jul 2013
          • 239
          I have add a few drop of this treadlock http://www.bsi-inc.com/Pages/hobby/thread.html ic loc blue, it stands it not compatible with plastic, what do they mean here? will it take damage to the plastic or just that it not will glue on plastic?
          I have fiberglas hull but i dont know if it mixed With plastic, and since the screew going trough the hull then the hole in the hull got this Product on the fiberglashull
          • tlandauer
            • 5666
            It will not look with plastic, that's what it means. If you don't plan to do any removal and really want this screw to stay, clean all surrounding goob out, put a few drops of CA, wait, was that you that had no CA in your area? I forgot, but CA does stick to metal.
            • waterproof
              • Jul 2013
              • 239
              Hi! :)
              I could buy a Product like a CA if CA is a Product like a thin floating fastglue that get stiff on a few seconds? I have add powerglue from locktite, its more like a epoxy and when it dryes its a bit soft, not bone hard if you know what i mean.
              • tlandauer
                • 5666
                CA is thin floating glue and dries in a short time---depends on which thickness you buy. Thin=instant, medium =10-15sec. to set, but takes longer over all. Thick=can be slow.
                I recommend the thin ones as you can count on it getting cured. most of them dries bone hard.
                • iop65
                  • Mar 2013
                  • 367
                  change them with stainless M3 bolts and nuts(with nylon locking ring)
                  do it properly and don't go messing with glue or things to fasten that screw,will not hold
