Esc Question???
  • tth
    • Apr 2008
    • 1510
    Esc Question???
    WHEN YOU LOOK AT THE HYDRA HIGH VOLTAGE AND LOW VOLTAGE ESC'S IT LOOKS LIKE SEVERAL SMALLER OF THEIR ESC'S STACKED AND SHRINK WRAPPED TOGETHER. TO GET TO THE POINT WOULD I BE ABLE TO RUN DUAL SV27 ESC'S PARALLEL AND GET 90 AMPS??? I'M NOT AN ELECTRICAL ENGINEER BUT IT SEEMS LIKE IT WOULD WORK?
    OR WOULD IT GO >>>>>>>>>>>>
  • chirotray
    DocFowler
    • Jun 2008
    • 139
    Think the first thing to tackle would be motor wiring, you cant run multiple brushless motors on one esc, or multiple esc's on one motor. If your talking about somehow connecting the boards together and disabling the sensory feature on one then maybe, but better refer to the electrical engineers on that one.
    Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
    • Jimmy Sterling
      • Apr 2008
      • 393
      I did'nt think that it was possible to run twin BL motors of a single speed controller.
      Come to the FASST side
      • Jeepers
        • May 2007
        • 1973
        its not possible to run 2 brushless motors on one esc. each motor must have its own esc.
        • tth
          • Apr 2008
          • 1510
          My Question Was Running 2 Esc Units In Parallel To One Motor. To double amperage.
          • NorthernBoater
            • 811
            It is not possible to run two ESCs on one motor. There is a small board on the Castle ESC that allows them to stack it. I would assume that this syncs the boards with the transistors on them.
            • Jeepers
              • May 2007
              • 1973
              sorry read it backwards
