Motor ESC bullet Connector Hot
  • hnm738
    • Feb 2013
    • 24
    Hi, i have Mean Machine Cat, running leopard 4074 2200kv, dual lipo 4s 5800mah 30c, M445. esc T180, 0 timing.
    all connectors are 6mm
    the motor and esc is 40 degrees (104F) but the connectors between the motor and esc reached 80degrees (175F)
    i thought it could be bad soldering , but i redid my connectors again but same results.
    what do you thing is the cause? do i need to go to 8mm connectors?
  • hnm738
    • Feb 2013
    • 24
    Strut is 1/4 above sponson and rudder 4.5" long
    • SirBudman32
      • Aug 2011
      • 625
      4072 2200 is a Y wind motor, you need to set timing to 15 deg. Y wind need higher timing a D wind need lower timing.
      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
      • martin
        • 2887
        Yes up the timing to 11-15 degrees, 30c batteries are on the low side for boats also.
        • hnm738
          • Feb 2013
          • 24
          thanks, will give it a try this weekend
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            3rd on the timing. 15 degrees
            • gsbuickman
              • Jul 2011
              • 1292
              Good information to know. I am getting ready to get my mean machine in the local boat hole, for a shakedown run before i start making changes to it.
              Currently she's running a stock ul-1 setup. turnigy 60a esc, 2030kv 50 amp motor, octura m455 prop set level with the sponsons, 2 rev-tec 6000mah 28c bullet pack lipos in series with deans harness on 10awg wire. The rudder is a swing away rudder with h20 pick up, as well as a sponson pickup, twin outlets & water cooled motor mount besides the esc & sleeve.
              I also have 2 thunderpower 4800mah 50c packs I could run in parallel, but after I upgrade the esc & go to bullets......
              • Heaving Earth
                Banned
                • Jun 2012
                • 1877
                Raise your strut way up
                  Mean Machines usually need the strut well above the sponsons as HE stated. Start with the bottom of the strut about 3/16" to 1/4" above the sponson bottoms. The ESC is on the small side, that setup can pull nearly 90 amps.
                  • gsbuickman
                    • Jul 2011
                    • 1292
                    J was thinking 1/4'' if needed, but I don't want to go to high & drop off plane. I am not real concerned with smokin' speed. The closest water hole is about 80 yards long, 45' wide & shaped like a kidney bean. Its 3 blocks away & 20' off the pavement so its real convenient. :)
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      I remember Fluid giving me that same advice a few years ago on my MM. Made a world of difference.
                      From memory a 42mm prop was around 3/16 and a little higher for 45mm props.
                      • gsbuickman
                        • Jul 2011
                        • 1292
                        Kool, thanks ozz. J raised it up as far as she would go.. 7/32'' was all it had, ha ha ....
                        • hnm738
                          • Feb 2013
                          • 24
                          I change the timing 11.25 and 15 degrees on the weekend, still no good, bullets were too hot to touch, motor, esc and battery were just warm.
                          • tlandauer
                            • 5666
                            How long are these wires between the motor and the ESC? Are the prongs of the male bullet having full contact inside the female bullet plug? ( no pun intended)
                            You said you redid the solder, which side? sometimes the factory solder job on the motor can be bad too----in case you only checked the ESC side since you suspected your job.
                            • keithbradley
                              • 3663
                              Bad solder, even after you attempted re-soldering...that's my guess. Maybe try a different method/approach to soldering your connectors?
                              I think 90%+ of the hot connector issues people have are caused by poor soldering. I have personally pulled as much as 350A through 5.5mm connectors and don't have hot connector issues. The resistance is typical of poor soldering more than it is a connector that is too small.
                              www.keithbradleyboats.com
