Hi guys, sorry if this post belongs somewhere else, this is my first day in the forums. Anyways, I could use your help.
I have a 44" deep vee hull and am having issues. I am currently running a leopard 4082 1600kv motor on a turnigy 5000mah 6s lipo battery. The esc being used is a seaking 120amp esc. Prop is octura x445. The boat uses 3 cooling lines, 1 off the rudder into the motor jacket, and 2 for the esc off of extra water pickups next to the transom. The boat will run for about 10 minutes at a GENTLE pace, but when I want to run the potential of the system, it goes for about 1.5-2 minutes, rpm slows to a snails pace, rudder twitches out and eventually locks itself to either direction and I lose steering, but am still able to SLOWLY drive the boat in a circle. I had this setup in a 36" cat and it too had the exact same issues. A concerning Point I have is an esc programming issue. I set the esc to 6s, reverse (for when rescuing other boaters when mine is still running) and the timing to 10*. I have noticed though, that my forward/reverse setting never stays once I swap batteries or come back another day. This leads me to believe the esc is forgetting EVERY setting and therefore damaging something. I know the boat will FLY, I have given it full throttle after a small warmup for a test, but soon after it quits. Any help is appreciated. Thanks
