Transom water pickup location.
  • atechbh
    • Sep 2012
    • 388
    I am putting a transom mounted water pick up on my 36" team believer for a second water line. Where is the best location for it and what depth is best to
    Set it to?
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    This may not answer your question, but I thought I'd share this alternative solution. When I race-prepped my MC I removed the stock transom mounted water pickup in favor of a rudder pickup. Then to get separate cooling to the motor I did a simple propwash pickup. Works fine.
    • grsboats
      • Jul 2012
      • 975
      another possibility
      Gill
      GO FAST AND TURN RIGHT !
      www.grsboats.com.br
      • Mike Caruso
        • May 2012
        • 940
        Originally posted by grsboats
        another possibility
        Gill
        [ATTACH=CONFIG]104091[/ATTACH]
        Clean and a very small water hole in the rudder reducing drag.
        Do It Like You Mean It .....or Don't Bother
        • shannon87
          • 222
          hi tony nice job on the prop wash pick up would love to buy one haha for some of my boats where i have got no room on the transom for traditional pick ups as the aeromarine prop pick ups are over 20 bucks haha sorry to hi jack this thread
          • iridebikes247
            • Dec 2011
            • 1449
            Have you ever used a thru hull water pickup? They're really easy to install and drag is kept to a minimum also the cheapest at a $1.75 on kintec.
            Just drill a hole in the hull and epoxy into place.
            • atechbh
              • Sep 2012
              • 388
              Does this last one have lots if water flow?
              • JLShip
                • Jul 2013
                • 74
                No need using a thru hull pick up, the ways Tony and Gil showed you in there reply's works out great , I ran one on my Aeromarine Conquest Gas Cat similar to Tony's and have run Gil's way on a Insane Gas Mono.
                RC Grandpa
                NAMBA Dist. 9
                Folsom R/C Modeleers
                • iridebikes247
                  • Dec 2011
                  • 1449
                  Thru hull water pickups rely on pressure under the hull to push water through the system. I run these in all of my boats, I noticed boats ran better with through hull pickups but then again these were 80+mph boats.
                  • JLShip
                    • Jul 2013
                    • 74
                    I wasn't saying, thru hull water pickups don't work, if done properly, just that the pick-ups mention, are easier to install, and will take care of any water flow issues in the Team Believer......
                    RC Grandpa
                    NAMBA Dist. 9
                    • iridebikes247
                      • Dec 2011
                      • 1449
                      tfl_521b20.jpgoh no i didn't think you said they didn't work lol, i was saying my SAW boats ran better with thru hull but then again this is a team believer so the benefit of thru hull is probably not as great as its not going 90mph. they make a new one at kintec its like 1.75$ figured I'd throw it out there.
                      • JLShip
                        • Jul 2013
                        • 74
                        [ATTACH=CONFIG]104270[/ATTACH]oh no i didn't think you said they didn't work lol, i was saying my SAW boats ran better with thru hull but then again this is a team believer so the benefit of thru hull is probably not as great as its not going 90mph. they make a new one at kintec its like 1.75$ figured I'd throw it out there.
                        Is that a little NY
                        RC Grandpa
                        NAMBA Dist. 9
