Mini Zonda & Rocket Upgrade
  • Monica Smith
    • May 2013
    • 162
    Please see the below photo of Mini Zonda.
    Hull dimensions :
    Length:69cm
    Beam:20.5cm
    Depth:10.5cm
    My friend would like to upgrade it with 3665KV2800 motors(dual motors), 120A ESCs, but I am not sure the hull can stand such strong power or not.
    Mini Zonda
    Rocket
    Hull dimensions:
    Length:650mm
    Beam:200mm
    Depth:110 mm
    Upgrade with 3665KV2800 motor, 120A ESC.
    When we are no longer able to change a situation, we are challenged to change ourselves.
    Email: monicagong76@qq.com
  • kendt
    • Jul 2011
    • 557
    Its CF so it should be pretty strong.
    • Monica Smith
      • May 2013
      • 162
      Thank you,Kendt.
      The original configuration of the Rocket is 2958(KV2881)Motor and 70A ECS. The hull made from Fibre Glass.
      Regarding to the Mini Zonda, has not been setup with any hardware yet. Refer to its hull dimensions, do you have any suggestions for that? Also I worry if install dual motors of 3665KV2800 motor, that hull may be can not stand strong power.
      • TOFTS
        • Aug 2013
        • 15
        Hull dimensions :
        Length:69cm
        Beam:20.5cm
        Depth:10.5cm
        Mini Zonda
        [ATTACH=CONFIG]103527[/ATTACH]
        Pretty tight in there no matter what twin https://www.facebook.com/media/set/?...0198315&type=3
