can you run 2p using different C ratings?
  • WhatRLaws4
    • Sep 2012
    • 64
    ok, so in short, is the following safe to run?
    A 4s 5000mah 40c paralleled to a 4s 5000mah 65c for 4s 10000mah, then wired in series to an identical 4s 40c and 65c confirgurationfor 8s2p?
    Better question, would you do it?
    • lenny
      • Sep 2010
      • 4294
      Like I said,
      Mixing brands is a bad idea.
      Only if they were all the same brand cells,
      Than yes I would say you should be good to go.
      ? ONLY IF THEY WORK
      • Bduncan
        • Jan 2013
        • 296
        Max amps told me the only deviation from identical is if the only variable is the cells. Say a 3s 5000mah 80c pack can be run in a series with a 4s 5000mah 80c pack for 7s. Makes sense, but i am not an expert.
        • Bduncan
          • Jan 2013
          • 296
          Only deviation is cells. Brand same mah same c same plugs same friends of battery same
