IM31 strut or MG29 strut?
  • NorCalZ71
    • Jul 2011
    • 293
    Converting a blackjack26 to strut and offset rudder.. is there any difference between the Im31 strut and the geico strut? I'm getting an impulse 31 flex from a friend and I'm just curious if I can use the mg strut? mainly because it comes with mounting brackets.
    Kevin
    NSR Customs
  • NorCalZ71
    • Jul 2011
    • 293
    Anyone have an Im31 and a geico they can compare the struts on?
    Kevin
    NSR Customs
    • iop65
      • Mar 2013
      • 367
      hello Kevin
      i have both ,mesured the strut for you :
      the MG stut is a few mm longer then the Impulse 31 strut :3.9 mm
      • NorCalZ71
        • Jul 2011
        • 293
        Longer in what dimension? Thanks!.
        Kevin.
        Nsr customs.
        • J.W. Pepper
          Check Out BJ26-v2 Parts
          Kevin,
          Are you wanting to do the conversion because your boat came with the steerable outdrive??
          If yes, on the BJ26 v2 boats - they're called: "Blackjack 26 SS BL Catamaran 2.4 RTR" - PB replaced the outdrive with an offset rudder and strut. Go here... http://www.proboatmodels.com/Product...rodID=PRB3300S - and check the parts list, I attached a pic of the transom I got from that page.
          I checked HH, those parts are still available...
          and...
          Using those factory parts would probably be the easiest way to make the conversion, prices are about on par with aftermarket stuff, and those parts made for the exact model of boat you have so you don't have to Mickey Mouse anything.
          Just some food for thought...
          Kevin
          NSR Customs
          • NorCalZ71
            • Jul 2011
            • 293
            Yea 2 of my friends went that route. I don't like the 1/8th inch shaft and set screw on the flex so I decided to go with a one piece shaft from the newer models..
            Kevin.
            Nsr customs.
            • iop65
              • Mar 2013
              • 367
              Hello Kevin
              3.9 mm = about 0.154 inches
