I've got some packs that have been re-configured (thanks Paull!), but I need some shrink wrap to finish them off. Anyone know what size works best with 2S and 4S Thunder Power packs (both 5,000 mAh)?
Heat shrink size for lipos?
Tags: None -
Found this Scotty. It should work.
http://forums.offshoreelectrics.com/...hp?albumid=320 -
Thanks Paul, I'll give it a try!Comment
Ended up going for the 90mm version, looks like it will work a treat!Comment
90mm verson was perfect for the 4S pack. Some old sub-c shrink worked a treat for the 2S packAttached FilesComment
Excellent.
I've got some of the 130mm for a couple of 6s packs that I've repaired & needed re-shrinking. Plenty to spare if you ever need any.
See you next Sunday.
Cheers.
Paul.Last edited by 785boats; 08-16-2013, 08:44 AM.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Shooter, Paul (785boats) did mine for me, so he may be able to help. I had a 4 cell drop a cell, so it became a 2 cell, and two 2S packs became a new 4 cell pack. Swapped the balance leads between them, so it all worked out well.Comment
