I plan on opening a build thread when I can get rolling on this boat build. But for now my question is on stinger adjustment. I have machine tools (lathe and mill) to fabricate my own stingers. It would greatly simplify fabrication if they were non adjustable and perpendicular to the transom. I can offset the prop shaft bore to be low as possible. Right now I was thinking of going with 3/16 prop shafts with cross drilled oil impregnated brass bushings,(but looking at "plastic" bearing material too) and using .074 wire drives which I would also fabricate. This is for twin fightercat 3730s 1600kv 2700W on 6s in a 41" sprint cat. Not sure if the 3730s are going to be enough grunt for this hull. Anyone have input on any of this? Is angle adjustment away from parallel with the bottom required? Since there is no transom overhang, how long should stingers be on this hull? Bearings vs bushings, bearings move the prop shaft higher on the transom. I welcome any input you might have.
Thank You!
Thank You!
