Help required on prop selection for 6s rigger
  • StevenBryant
    • Nov 2012
    • 359
    Hi guys as the title says i need help selecting a starting prop size for a 6s rigger, the motor is a leopard 4074 1600kv, the boat is a scratch build similar to an EAGLE SG with a few modification to alow for FE rather than nitro, i'm running the swordfish 200amp 8s esc.
    cheers
    Steve
    What is the size of the rigger? That is not a large torquey motor, I'd start with an m545 depending on the size/weight of the rigger.
    • StevenBryant
      • Nov 2012
      • 359
      The tub is 35" long with the sponsons taking it to 36", its not a light rigger as it was built to run in choppy conditions, i have a 1445 and 1450 cut back to 44.5mm so i will start with these, thanks for your help.
      • RaceMechaniX
        • Sep 2007
        • 2821
        You might also try a ABC 1814 or 1714 to start with.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • StevenBryant
          • Nov 2012
          • 359
          Hi guys sorry i slight mistake, the motor is the Leopard 4082 1600kv not the 4074
