cg on mono
  • ChoppyOne
    Just Addicted !
    • Apr 2013
    • 121
    cg on mono
    I built an old prather aggressor II (41" x 10.5") first build I set the CG up at 28% (11.5") from back. The boat moves good in the water except in cornering ! its like it rocks back and forth from front to rear sometimes rear lifting out of the water very unstable in corners. any suggestions ? Help? im running a 40x92 1730kv Leo with a prather 245 prop I tryed a 647x3 oct it calmed down some yet still unstable .
    Thanks in advance
    Dave
    G1 Whip , Insane F1, FE VS1
    LSMBC Dist 7 Namba 1759
  • lenny
    • Sep 2010
    • 4296
    Did you try tucking the rudder a little ?
    And can you post some pictures up of the boat hardware and the setup in the hull ?
    ? ONLY IF THEY WORK
    • ChoppyOne
      Just Addicted !
      • Apr 2013
      • 121
      securedownload.jpgshe devil.jpgHeres some shots Lenny........I read on OSE about rudders causing this is it too deep? to high? like i said first build
      Thanks in advance
      Dave
      • lenny
        • Sep 2010
        • 4296
        By tucking the rudder,
        I mean for the bottom edge of the rudder to angle towards the transom just a little bit.
        It sounds like it is plowing to me in the turns and running wet.
        The stinger looks low to me,
        I would raise it so it is level with the bottom of the hull.
        Use a straight edge a cross it.
        Also tabs at level to, With a straight from the bottom of hull to back tips of tabs.
        Show us some pictures of the in side setup with the cells in place please.
        ? ONLY IF THEY WORK
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          Choppy.
          I would say that there is not enough rudder in the water.
          The rule of thumb I like to use is, at least the diameter of the prop hanging below the bottom blade of the prop. It also looks as if the top water intake is level with the bottom of the prop hub. There's a good chance it will be picking up more air than water and not cooling things very well.
          The turn fin is possibly a bit high too. The tip is well above the waterline when running level so there is room to drop it a bit or put a larger fin on the existing bracket. There isn't enough in the water when the boat turns. That also adds to the bad handling characteristics in the turns.
          Just my thoughts.
          Paul.
          • lenny
            • Sep 2010
            • 4296
            Good points you have there too.
            ? ONLY IF THEY WORK
            • ChoppyOne
              Just Addicted !
              • Apr 2013
              • 121
              ill try that had to adjust positive angle too keep the front down and also think im twisting to large of a prop (prather 245) as my batteries are swelling. ill shot some of the inside and post here in a min.
              thanks
              Dave
              • ChoppyOne
                Just Addicted !
                • Apr 2013
                • 121
                Thanks I will try that, I did notice both water outlets were spraying water but i can drop the rudder and try.
                Thanks again
                Dave
                • 1truckerdan
                  • Aug 2011
                  • 329
                  ChoppyOne here is a link to a site that I learned alot from
                  When you know it all.......you never will learn anything new
                  • ChoppyOne
                    Just Addicted !
                    • Apr 2013
                    • 121
                    http://www.modelpowerboat.com/conten...-hull-attitude
                    Thanks im on the way over..........Dave
                    • 1truckerdan
                      • Aug 2011
                      • 329
                      @ ChoppyOne,
                      I hope that link helped you figure it out.
                      Daniel
                      • ChoppyOne
                        Just Addicted !
                        • Apr 2013
                        • 121
                        real good info Thanks , I do have one ? the further back you set a rudder it does what ?
