Cooling lines on Revolt 30
  • PawPaw88
    • Jun 2013
    • 27
    I've seen discussions on the board that the water cooling lines should go thru the ESC first then the motor .Looking at the schematics of the Revolt 30 it looks like the line goes thru the motor first then the ESC and out. If I were to buy the Revolt should I reconfigure the cooling lines.
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    If you plan to run stock set up you do not need to do any with the cooling.
    The system stays cool out of the box, no worries about temps....
    Canada
    • G-UNIT
      • 949
      True, but most run the line thru the esc first then into the motor, also the line going into the motor should enter the bottom and exit at the top and then out.
      • PawPaw88
        • Jun 2013
        • 27
        Thanks much for the ingo
        • Ken Haines
          Racer
          • Jul 2007
          • 647
          On spec motor set-ups like the Revolt, the motor is the weak link.
          The priority then is to cool the motor fiirst, then the ESC second.
          Aquacraft got it right........probably on the advice from their Team racer Brian Buass
          who started this advanced cooling practice many years ago. I remember asking him
          about this cooling arrangement after buying one of his Raptor riggers about 5 years ago.
          He explained the rational that has worked well for many years.....Thanks Brian.
          TenShock Brushless / Pro Marine
          INSANE Boats / Rico Racing/ Castle Creations
          2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
          • PawPaw88
            • Jun 2013
            • 27
            Thanks very much Ken for the info.
            • mannytx1
              Fast Electric Adict!
              • Oct 2012
              • 99
              I am sorry but I disagree with you
              Water cooling system it should go through the esc first because it won't heat up the water enough to make a difference on the cooling on the motor. But if you run it through the motor first it will heat the water and then the water will heat the esc
              REVOLT30 6S
              • Jeff
                • 232
                Depends on what is hottest. In my revolt the motor is hotter than the esc, so I cool the motor 1st. Pretty basic, just use your temp gun after a run.
                I try and avoid paste eaters.
                • tlandauer
                  • 5666
                  Thanks Ken for posting this. Whether it is ESC first or motor first, I appreciate these insightful stories. I always learn from these side notes that it doesn't matter even if they don't apply directly to my situation.
                  • Bduncan
                    • Jan 2013
                    • 296
                    Easy to solve this with dual cooling. 1 for esc 1 for motor.
                    • PawPaw88
                      • Jun 2013
                      • 27
                      Great thought Jeff...............I'll make a run or two and check temps.
                      • Bduncan
                        • Jan 2013
                        • 296
                        I think many would agree. Don't overly mod out these little stock boats. By the time you start putting a new esc motor, hardware bigger batteries etc... You most likely would have been better off with some derivative of a build. I started with revolt and a spartan. I put 600 bucks in the revolt to get it to 55. One flip and destroyed it all and lost a 200 dollar battery.
                        • PawPaw88
                          • Jun 2013
                          • 27
                          What are ideal temps for the motor and stock ESC on the Revolt ?
                          • Jeff
                            • 232
                            38 degrees fareheit. you did say ideal.
                            • tlandauer
                              • 5666
