Hi,
due to that my old Bittburger cat from precision in perfection have been running for over 10 years and only run a single setup, I'm considering to upgrade to a twin drive cat.
Have been serching around and going for the MHZ Mystic c5000 84cm/smal cat. Planning to run with MHZ recomended drives, rudder, servo/battery/motor mounts, 2x 3s 5000mAh packs, 2x 2500-3000kv bl motors and 2x 120-180amp watercooled esc's. For propellers I want counterrotating props with 3 or more blades.
Have been looking on turnegy 180amp esc's and 3-blade alu-props from tenshock...
Not sure about the ideal kv for this setup but have figured that around 2500kv will give both some runtime and great speed but not SAW insane speed ;-)
Do You have some good advise for motors, esc's, propellers etc that You can recomend and also links where especially I can order propellers from?
