mean machine offset rudder?
  • sampit
    • Jul 2009
    • 447
    the recomended rudder and strut is the Speedmaster 21 strut, round bottom-hydro design
    Ose-80050 Rudder.
    would this hull perm better/or as good with a offset rudder and strut like this
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    This is not my MeanMachine, but mine is set up the same way and runs very well.
    • sampit
      • Jul 2009
      • 447
      Thanks Jay
      Could I use a 130 rudder or woulld 130mm be to long?
      thinking i might use a 4074 1400kv motor on 6s any idea on prop x440?
      • Basstronics
        • Jun 2008
        • 2345
        Look for my build thread. I believe that is the dame hardware I used. Haven't got mine wet yet but it appears to be a good fit .
          I would not want to start with a shorter rudder. When I first built the MeanMachine I used the "mini" SpeedMaster rudder (100mm long) and the boot hooked terribly. That was cured with a longer rudder (150mm).
          ..thinking i might use a 4074 1400kv motor on 6s any idea on prop x440?
          That would be a place to start, giving speeds in the low/mid 40s. A lot depends on what you want from the model as far as speed and run time. That hull can handle props up to at least 45mm, so you could prop up for more speed with the 1400 Kv motor, or pick a lower Kv (1200) and get good speed with longer run times. A longer motor will handle heat better and swing a larger prop.
          • NativePaul
            Greased Weasel
            • 2761
            Mine came with a 90mm rudder and handled poorly, i switched it for the same 130mm rudder you linked to and it handles very nicely now,it seems well suited to the hull.
