T120 esc
  • sampit
    • Jul 2009
    • 447
    T120 esc
    Wondering what hull I could build to use up a few spare parts i have lying around
    i have a T120 ESC and a Dinogy 6s 5000 65c pack also a TP 4082 1450kv and a TP4074 2200kv and a few 4s 35C packs
    Any advise on a hull I can buy but not a mono hull as i have two already?
    thinking maybe I would get away with the 2200kv motor on 4s but maybe the 4s setup would be pushing the little T120 to the max but maybe the
    6s setup would use less amps, but maybe both to much for the T120 but would like to use if i can without any added expense buying a T180
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • G-UNIT
    • 949
    The 2200kv motor and the t120 esc will work fine togeather on 4s but you will more then likely burn up the motor and or the esc on 6s.
    a hydro like the ul-1 will move out nicely on 4s with that motor/esc combo.
    also a cat in the 29" range would work on the 4s setup.
    I"m sure others will chime in also.
    the 1450kv motor will handle a 6s set up with a t180 esc.
