Revolt 30 - Motor Upgrade
  • IFlyEm
    • May 2013
    • 21
    Looking at putting a new motor in my Revolt.
    I will be running the Seaking 180 on 4S 5000mah 30-40C.
    Any opinions on running a Leopard 3674 2200kv vs Leopard 4074 2000 or 2200?
    If you aren't flying on the edge you're taking up too much room!!
    http://www.iowacityaerohawks.com/
  • stadiumyamaha
    • 1284
    A ul1 2030kv works very well in one. Also, set up right the boat will run a long time on 5000mah.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • IFlyEm
      • May 2013
      • 21
      Do you think there would there be any benefit running a 4074 over a 36mm motor in this boat? How does the 2030 compare to your leopard 3674 2200?
      • stadiumyamaha
        • 1284
        The boat is so light that it just doesn't need a bunch of torque like the 40 or bigger has. I bet a 3674 2200 would work great.
        • IFlyEm
          • May 2013
          • 21
          Cool...thanks! On a side note I see you are a Yamaha guy. I love my Yammy snowmobile. Just finished putting a prototype twin screw blower on it.
          • IFlyEm
            • May 2013
            • 21
            What prop would you think with a 3674 2200kv? I may try it.
            • BHChieftain
              Fast Electric Addict
              • 1969
              I like the x440 on my 29" mono which uses a neu 1515 2200kv motor.
              Chief
              • capnswanny
                • Feb 2012
                • 817
                While you're wating for the new motor to show up....I have had great success running the stock motor and ESC with an m645 prop.
                I'm using inexpensive HK 4S1P 4000maH packs and consitently run cool in the mid to upper 40's for a good long time.
                I tried a UL-1 (2030kv) and didn't gain much at all.
                Here's the thread I was posting to
                http://forums.offshoreelectrics.com/...t-Breaks-60mph
                I'm curious to see how yours runs with that bigger motor!
                This is NOT a toy?!?
                • stadiumyamaha
                  • 1284
                  Mine ran better on a x642 than it did on the 445 for general sport running.
                  I'd like to see the sled. We don't have them here but we do sell a bunch of parts for them online.
                  • IFlyEm
                    • May 2013
                    • 21
                    You like the m645 better than the X642?
                    What speeds are you getting?
                    • IFlyEm
                      • May 2013
                      • 21
                      Here is my sled before the blower. I'll get more videos once the snow flies!
                      Here's my other pride and joy!
                      Now if I could only get my boat to do 300 mph!
                      • capnswanny
                        • Feb 2012
                        • 817
                        I do like it better, probably because it's the fastest on my boat :)
                        I topped out at 46.9 on the GPS with the 1800KV, 60AQ ESC, 4S1P 40C pack.
                        Once I had the pack all the way aft, I adjusted the strut for nose-up just a hair and it came alive.
                        M545 was my second favorite.
                        I just took a pile of batteries, my buddies prop box, and a GPS to the lake and tested for a few hours.
                        If you have that luxury, it's the way to go!
                        • capnswanny
                          • Feb 2012
                          • 817
                          That's awesome!! What a pilot!!
                          • IFlyEm
                            • May 2013
                            • 21
                            Thanks! I've been flying for 25 years or so. I like it all. May even get a truck at some point.
                            • rogley
                              • May 2012
                              • 19
                              I have a revolt and I put a leopard 3674 2200kv in it. I run a octura 442 on it. This thing is a hand full. The boat is so light you will need to put some weight in it and do some adjusting to keep it on the water.
