Revolt flex shaft problem
  • rogley
    • May 2012
    • 19
    Has anybody had a problem with there revolt breaking there flex shafts.
    I have broken 3 and I see no problems with the drive unit or tube.
  • martin
    • 2887
    How much gap do you have between the drive dog & the strut.
    • siberianhusky
      • Dec 2009
      • 2187
      Where are they breaking? Near the stub shaft or farther up towards the motor?
      I haven't heard of many issues, I don't own a Revolt, I have 3 other AQ boats though, was thinking about one until I got a good deal on another boat.
      A young guy around here has one, nice running boat, don't think he has had any problems yet.
      I'm a big fan of Hughy flexes, been using them for years in electric and nitro boats. Replaced the original in my Motley with a Hughy, that one did have issues with the flex cable in the first releases.
      • rogley
        • May 2012
        • 19
        I have been keeping a little over 3/16 of an inch gap. They are breaking right where the flex goes into the prop shaft.
        • martin
          • 2887
          I take it you have checked the alignment of the tube & the coupling, also is the coupling running true.
          • jfrancisco892
            • Feb 2012
            • 546
            Get a Hughey. Make life easy
            • rogley
              • May 2012
              • 19
              How good are a hughey and where do you get one? What makes them better?
              • Darin Jordan
                • 8335
                Is the motor mount moving around and allowing the flexshaft to rub against the brass stuffing tube?? Is there teflon between the shaft and the brass??
                Darin E. Jordan - Renton, WA
                • Rumdog
                  • 6453
                  Is it a stock setup?
                  • Doby
                    KANADA RULES!
                    • 7280
                    Are they breaking , or coming apart due to poor soldering from the factory?
                    I just had a brand new AQ SV-27 cable go on me after 1 minute, when I got it back to shore, the flex had come out of the shaft.
                    Grand River Marine Modellers
                    • rogley
                      • May 2012
                      • 19
                      Yes I am running a stock set up.
                      Darin the stuffing tube is stock. The Teflon liner is still in the tube.
                      Like I said before all three cables broke right where the flex meets the prop shaft.
                      • rogley
                        • May 2012
                        • 19
                        Hello Doby
                        All three cables are all the same size. I don't see any solder. They look like they twisted out of the prop shaft
                        • Doby
                          KANADA RULES!
                          • 7280
                          Ah ha! Probably poorly manufactured. It happens.
                          If thats the case, they can be cleaned and re-soldered...thats what I have to do with mine.
                          • rogley
                            • May 2012
                            • 19
                            Hello Doby
                            The problem with that is the props and prop shaft are on the bottom of the lake.
                            • eboeske
                              Fast electric addict
                              • Mar 2012
                              • 142
                              My opinion is that's not the proplem only because one of the flex shafts was mine i ran it 10- 15 runs in my boat with no issues when we put it in his revolt 2 seconds and it was gone. Something else going on here. Not to mention an expensive issue when you calculate the cost of 3 sharpened and balanced props and the flex cables.
                              River cat,Aquacraft revolt,Mini mono,DF 33,DF29.
