For those who have the Hydra 120...do you notice the 2 caps being bent one way or the other? Any thoughts for protecting them? Maybe solder a small piece of copper perpendicular to and across the water cooling tubes to serve as a stop so they can only go so far?
Hydra 120 capacitors
Tags: None
I gooped some Silicone in between and around the caps on mine. It helps keep them in place. Thats one part of the Hydra's that seems to be a poor design.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellers -
GHot glue is a good idea,,,IF the controller stays cool, otherwise you risk melting the glue!Grand River Marine Modellers
There is only 1 way to find out I suppose.
My other though was high temp RTV red gasket maker, by Permatex. Do you think the chemicals would damage the electronics?Comment
Just go with the plain old silicone, it will do fine.Grand River Marine Modellers
As long as you keep it on the casings of the caps, then all will be good!Grand River Marine Modellers
