I think it looks like the holes is drilled wrong.
If you dremmel a path to the hole, you might dremmel into the channel to the lower hole.
The top hole should be in front of the lower one, then this would not be an issue...?
) was to fab a "scoop" from JB weld ( greased up a tiny drill bit, laid it in the groove, JB'd and trimmed before it cured & slid out the greased drill bit just prior to curing.) In your case you'd need to do this on both sides for both pickup holes - may not be worth the trouble but who knows ?
. The spartan outlet is like a hose when it comes in close at speed
