I installed the motor, and the servo. and th cooling lines.
Instead od using bulkhead fittings. i used the 1 size larger tube holder method, just like the stuffing tube, and the cooling exits. Now, all the hull penetrations are removable!!
Here you can see the grommets Im using to hole the lines in place, the just slide into the holdes I made easy. YOu can also see that the tube passes through the hull
longer view
longer view
