after finishing the build i took the boat out and it seems to me the boat sticks to the water way too much the prop is down as much as i can go i cant seem to lift the front of the boat up here is a video open to any input leo 4082 2200kv with 2 3s pack
cheetah help
cheetah help
2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeTags: None -
2 3s packs It seems like by keeping it all the way down pushes the boat up if I have the strut higher up it pushes the front of the boat more down. I have the battery packs almost all the way in the back as well2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
Yeah but are you running series for 6s or parallel for 3s? That's a 4s motor. On 3s its not gonna get up on a plane really, and on 6s that thing should be taking flight and catching fireComment
lol 2 3s in series i know what ur saying i did it with 4s1p and it didnt run as good i checked temps running 3s2p and it was cool to the touch as if it wasn't even running at all what do you think i need to do to get this thing running good2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
Yea. 1 battery's + to + of esc 2 battery's - to - of esc and a wire between the 2 battery's +&-2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
Ok. Well it seems that there is another issue somewhere. On 6s that thing should be absolutely screaming and possibly self destructing. Not sure what exactly you have but go thru every piece of eq you have in it for usComment
Maybe the motor is too small, but it just doesn't sound like the rpms are up there. My 2200 on 5s has a much higher pitched whine and will blow by that like its standing still. Of course it's a mm so it's a tad smallerComment
From experience...put the strut at 1/4" above the bottom of the sponsons with the hull sitting on a flat surface. Set the cener of gravity at 30 percent measured from the back of the sponson not from the back of the transom. My Cheetah with a Leopard 4082/2200 on 4S2P runs great......yours can too.
CG3Comment
radio is a tactic. Esc is a turnagy 180. Modes. Forward only. low voltage set to off Set to 15deg timing2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHomeComment
