1521 1.5D 1900 kv in an outrigger- nprop and battery recommendations
  • morewattsnow
    • Oct 2010
    • 192
    I have a Neu 1521 1.5D 1900 kv motor I want to run on 5s in an outrigger. A TP7700-5spf70 will fit nicely. Think a T-180 can handle this and what would a good starting prop. I think I also have room to move up to a CC 200 amp controller if need be. Anyone see any terrible mistakes I'm making? RPM's calculate out at just over 35,000 and I've run 37-38,000 in the past with no issues. Any advice (especially Fluid) would be greatly appreciated. Thanks.
    Fast Electrics Have A Small Carbon Wake
  • photohoward1
    • 1611
    No a T180 will not work. Most of us run our P mono set-ups with that Motor and a 450 prop. Very fast. What you are proposing is a saw set-up. I think you should look at the least least a 240 amp controller. Let others chime in.
    • morewattsnow
      • Oct 2010
      • 192
      I was pretty sure the T180 would be a little weak for what I'm going to do. It just happens to be in the boat right now with a smaller 1512 motor. I have a Hydra HV Ice 200, a Swordfish 12s 240 and a Fighter Cat 300 amp HV I could use. Would like to use the Castle unit due to space limitations.Think that would be adequate? Thanks for the input.
