12s mono
  • sampit
    • Jul 2009
    • 447
    12s mono
    What do you think the nicest looking and best performing sports mono hull would be to run 12s2p
    any idea of run time and speed around 50+ 65mph max
    Leopard 4092 700kv
    4 x 6s 5100mAh 65c packs the 65c rating is probably OTT but I have all the parts on the self just need to put them in hull
    16s controller Fliermodel and UBEC
    if I go this way, I can put all my parts in one boat and sell my other hulls, free me up no end.
    After thought!
    maybe a hull running 6s2p would be better
    thanks
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • NativePaul
    Greased Weasel
    • 2760
    Lindenau Deathstars seem to be the go to hull for Supermono on 8s or 12s 1120g, but they were designed for NiMh so would easily take the extra weight of 12x 5100 65c cells whether in 6s2p or 12s1p configuration, while they are big for FE boats its too small for 12s2p, you should be looking at 40"-45" and more than likely a hull that was intended for petrol/gas power.
    I went for the 43" MHZ DPX 24 Nimbus but haven't finished it yet so other than that the glass work on it is very good +as is usual from MHZ, and batboats tend to handle rough water very well I cant tell you much about it.
    • Jason4636
      • Jun 2012
      • 654
      I just built a MHZ mystic mono, it's 56"s long and 13" wide. And running twin 528's with twin SF 300's. Plus MHZ just released a 60" long by 11" wide mono.
