Gas to Brushless 64" bonzi fountain
  • neal58cobra
    • May 2011
    • 117
    I have a 64" bonzi fountain with a K30 engine in it now. I would like to convert to brushless as my other boats are brushless. I just looking for what other people have done with big boat conversions. I want to keep it a single motor and need ideas for motor, esc, and lipos. Any help would be appreciated. Thanks Neal
  • Jason4636
    • Jun 2012
    • 654
    The CC2028 if fairly cheap right now and it should push that big of a boat fairly good on 10s. Plus a SF 300amp esc should also work. And if you wanna save a few more $$ on your motor. The Beast 528 is the same as the 2028. just different maker
    • neal58cobra
      • May 2011
      • 117
      What brand are these? Have u used them or just think they will work? Looking for setups people are running now with little to no issues. Thks
      • Alexgar
        • Aug 2009
        • 3534
        havent built one this big but been researching for a big build 48" or so and heres what i have found
        http://www.hobbyking.com/hobbyking/s...ess_Motor.html
        http://www.hobbyking.com/hobbyking/s...tor_760KV.html
        a couple here
        and the castle
        hope that helps
        • Hor2012
          • Jun 2012
          • 348
          You can also check here. http://www.finedesignrc.com/motorsne...ackdiamond.asp
          2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHome
          • Alexgar
            • Aug 2009
            • 3534
            Way over rated and over priced leopards there Steve has then cheaper
            • neal58cobra
              • May 2011
              • 117
              Alex what are u refuring to? Are u saying fine design motors are nicer leopards and u would just buy a Nue motor?
              • gyrotron
                • Jul 2012
                • 481
                Hello neal58cobra,
                I just finished the boat below (1st build ever) with the help of fellow forum members. The build is a revival of a 42" Davete Aspect Shallow V gas hull I felt in love with and wanted to do an FE version. You may find usefull information for you application going to my build. The motor that I used is a Proteus x524 in delta configuration running at 910Kv with a 59mm 3 blade CNC aluminum propeller. The video does not deserve an Oscar but, at least it will give you and idea of what to expect. I am powering the boat with 4x4S lipos in a 8S2P configuration and it runs very well. This same motor setup powered with 10s should really fly but you would need a 300mAh ESC minimum.
                Here is the link to my build if you are interested:
                http://forums.offshoreelectrics.com/...c.-help-needed
                • Alexgar
                  • Aug 2009
                  • 3534
                  Fine designs motors are leoperds . As for the neu they are great depending on you budget if I had the money is buy a lehner but that's just a matter of preference, price and boating needs
                  • Alexgar
                    • Aug 2009
                    • 3534
                    As I've found I tend to keep motors when I sell boats so spending a little on electronics isn't such a hit on my wallet if it last 2-3 years
                    • Alexgar
                      • Aug 2009
                      • 3534
                      as for Steve I meant to check out the ode store the owner (Steve) sells most the same stuff cheaper
                      • neal58cobra
                        • May 2011
                        • 117
                        Gyrotron that is a nice build! Did u ever GPS the boat?
                        Alex thanks for the info.
                        I'm still gathering data on what I want. I would like to see the boat in the 50s to low 60s but it may cost to much. I don't want cheap stuff but I also don't want the most expensive stuff either. Is this even realistic of the speeds I'm looking for? From what I gather would a 10000 watt motor be a good start or do I need some more power? I also see an esc is also limited also. I think I will be running 10s lipos or 8s.
                        Again thanks for all the info and help guys!
                        • gyrotron
                          • Jul 2012
                          • 481
                          neal58cobra,
                          No, I do not have a GPS at the moment that will be the next device to get for the boat. Due to the pond size limitation at any point in the video, I had a chance to go WOT but I figure mid to high 40's in the segments of the video were it is going faster maybe 3/4 throttle. I believe my boat would reach the 50mph mark without issues if allowed to go WOT. On your build I would go 10S minimum and no less than 10,000mAh.
                          This is the motor I am running on my boat
                          It will push from 59" to 78" size hulls so it will work for your application just fine.
                            • 9488
                            Originally posted by Hor2012
                            yes, much better to buy them from a stand up guy like Steven here on his own site
                            an much safer and better chance to actually get what you pay for.......
                            • gyrotron
                              • Jul 2012
                              • 481
                              Yeah, Offshore Electrics also sells the Proteus I used. Buy from Steve!
                              http://www.offshoreelectrics.com/pro...Proteus+Motors
