Blackjack 29...hydra200...motor suggestions on 6s
  • Jason4636
    • Jun 2012
    • 654
    Lmfao!!!!
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      Mehehe
      • Xkillteam365x
        • Oct 2012
        • 16
        Lmao! Thanx guys! I appreciate all the help!
        • Xkillteam365x
          • Oct 2012
          • 16
          So I need some opinions on a TP Power 4082 1160kv- that's what I ended up ordering... What do you guys think? Any input?
          • Jason4636
            • Jun 2012
            • 654
            I would run that motor on 7s for a sport setup. And 8s for some fast runs. Just use the data log, run you a few time on 7s. And run a few times on 8s. I think it will be ok on 8s.
            • Xkillteam365x
              • Oct 2012
              • 16
              Im just gunna start with the x642... And go from there...thanks again Jason4636 for all the help!
              • Jason4636
                • Jun 2012
                • 654
                No problem, with that 4082 on 7 or 8s. You will probably be able to run up in the 50mm size props. Just start out small and work your way up
                • lomdel
                  • Nov 2008
                  • 708
                  I agree. 1160kv on 6S will be too slow for you. Safe, but slow. I have a Leopard 1400kv on 6S with a S180 ESC and it's plenty fast. Don't have logged speeds yet, but the grin-factor is enough!
                  • iridebikes247
                    • Dec 2011
                    • 1449
                    Thats going to be pretty slow dude. That tp power motor is very powerful especially in that hull you could prop up a lot but believe me a big low kv motor with a large prop to compensate can lead to weird handling. Small prop spinning fast works a lot better. I agree with above poster that leopard probably burnt up bc of the big prop. I've seen 2200kv 6s twin 4082s and they run fine.
                    • lenny
                      • Sep 2010
                      • 4294
                      That is way I like the idea of a 36mm 1400kv can in that hull,
                      And it will have plenty of power with out the bad handling problem to add to the mix.
                      ? ONLY IF THEY WORK
                      • martin
                        • 2887
                        Theirs a big difference re what rpm & prop sizes you can get away with when using twin motors compared with a single motor.
                        • Xkillteam365x
                          • Oct 2012
                          • 16
                          #27
                          Motor came In today! Tp 4082 1160kv with 8s on the x646...got 54.2mph...motor temp was about 117... battery's were 120... Esc was 105... Very tempted to run a bit bigger prop possibly x648... Still need to hook it up to the comp and see what that says...any suggestions?
                          • lomdel
                            • Nov 2008
                            • 708
                            #28
                            I really want to see a pic of the fit under the sub-hatch of that 4082 monster. Must be extremely tight... The two 4S lipos in there is probably also a tight squeeze. Pics please!
                            An X648 prop is huge for this hull, dude. Could work, but pe prepared for weird handling and higher temps.
                            • Xkillteam365x
                              • Oct 2012
                              • 16
                              #29
                              Pics coming soon! Actually I ran 2-3s on the battery trays which I customized... and a 2s up in front of the motor...actually the motor fits nice! I cut the sides on the platform where the esc and servo sits...the hull is completely reinforced with epoxy. The thing is a tank!
                              • Heaving Earth
                                Banned
                                • Jun 2012
                                • 1877
                                #30
                                Seems a bit slow for what you're running
