Question on battery setup
  • Hor2012
    • Jun 2012
    • 348
    Guys I built this boat to run on 3s2p but reading more and more I think I might have problems. I was looking to do mid 50s with a Leo 4082 and a 180t esc with a 447 prop. I had everything so I put it in a fighter cat cheetah. Should I go with 2s2p. What would my speeds be?
    2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHome
  • jstolz
    • 335
    I'm confused! Do you mean 6s1p instead of 3s2p and 4s1p instead of 2s2p? What kv is the motor? I'm not familiar with cheetah, but hopefully someone will be able help with speed.
    Jay
    • lenny
      • Sep 2010
      • 4294
      What kv is the motor ?
      ? ONLY IF THEY WORK
      • Hor2012
        • Jun 2012
        • 348
        Sorry I always mess up on the battery. I was planning on running 2 3s packs. And the motor is 2200kv. So that's why im thinking of going with 2 2s packs. But I was wondering what me speeds would be. I know with 2 3s it should b around 6ph
        • jstolz
          • 335
          That motor on 6s is a hot setup. I wouldn't run it for sport running. I'm thinking with 4s, two 2s packs in series, you could get into the 50's. I would start testing with a 45mm prop not a 47. That's a big prop. I would suggest an M445.
          Jay
          • Hor2012
            • Jun 2012
            • 348
            Jay
            What do you mean. Sports setup.
            • jstolz
              • 335
              I'm assuming that you are not going to race it, or just be sport running it.
              Jay
              • Hor2012
                • Jun 2012
                • 348
                No no racing just playing around in the lake. That's why I was thinking I could go with 2 3s packs
                • jstolz
                  • 335
                  For playing around you want to run on 4s, not 6s. On 6s, or two 3s packs, you will burn something up. The motor rpm will be too high. Things will get hot.
                  Jay
                  • Hor2012
                    • Jun 2012
                    • 348
                    Makes sense thx for the help now I know what battery's to order for that boat
                    • lenny
                      • Sep 2010
                      • 4294
                      That cat is 34"L x 13"W x 5.5 H and is a little bigger then my Mystic,
                      I would go with two 4s 40c 4000mah in parallel or higher mah if you have the room in the hull for them,
                      In my Mystic I am running them in parallel for pretty good run times and speeds to.
                      ? ONLY IF THEY WORK
                      • Heaving Earth
                        Banned
                        • Jun 2012
                        • 1877
                        I would go for 4s5000mah. 2s packs won't give you much runtime on that motor.
                        • Hor2012
                          • Jun 2012
                          • 348
                          So I should go with 2 4s packs in parallel for best results
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            Yes, I would
                            • Hor2012
                              • Jun 2012
                              • 348
                              Sounds good. Thank you
