Can a fightercat 300 mah 3-16s esc need cap bank to run 6s to 8s or thats just for hv set ups from 10s to 16s
fighter cat esc
Tags: None
Cap banks have nothing to do with the number of cells. They are used to reduce ripple current from inadequate batteries or long ESC-to-battery wires. If you use them for high voltage make certain that they are rated for voltages higher than you will ever use.
Thanks Jay for the technical answer. In a lays mans terms, I use them to be able to use the throttle more.Comment
thx for the knowledge I got a mono h urricane hull wit a 1020 6pole nemsis from Finedesigin with a 300 mah 3to16s running a 270 prop I'm getting 52 MPH on 6s and 8s 69.5 MPH running cool and good with a castle hydra 240 .want to see if the fightercat I put together runs betterComment
