Motor Mystery
  • Bill-SOCAL
    • Nov 2007
    • 1404
    Motor Mystery
    So here's one for you. My 32" DF Storm P mono has a Nemesis 10XL (1668 Kv) in it. Runs very nicely and clocks in at 48 to 50 mph running m445/m447/x646 props. Good temps too, never anything over 120 or so.
    But the FE NATS are coming up so I decide to install a Feigao 9XL I had sitting here. Figured I'd get a little extra punch from the 1853 Kv over the 10XL.
    Now here is where the mystery enters. Ran the 9XL yesterday and it is on average 5 to 7 mph SLOWER!!! Temps were a touch higher, by about 5 degrees over what I normally see.
    Same set up. Same ESC (Hydra 120, no firmware updated), same batteries (4S2P 5,000 25C Poly RC), NO changes at all to the boat.
    So can anyone explain to me how a motor that is 185 Kv higher (11%) can run slower by so much using the same props??
    The 9XL turns over silky smooth, no binding. Everything is as it should be mechanically. I am mystified to say the least.
    I can think of only 3 possibilities:
    1) the 10XL was miss-marked and is a 8XL or higher Kv
    2) the 9XL is miss-marked and is a 12 XL or lower Kv
    3) the 9XL is defective
    Any other ideas??
    Don't get me started
  • Doby
    KANADA RULES!
    • 7280
    I would go with the mis-labled theory
    All other things being equal, it sounds like the only expanation!
    Grand River Marine Modellers
    • SJFE
      • 4735
      I would have to say you have a miss marked motor Bill. You need to run some type of kv test to figure out what one. How thats done is beyond me.
      • Mich. Maniac
        Banned
        • 1384
        just outta curiosity what do you have hydra timing set at?
        • Bill-SOCAL
          • Nov 2007
          • 1404
          Same settings as the 10XL, which was the "normal" setting in the Hydra. Like I said, there were no changes made except the motor swap/
          I could use a drill press with a known RPM and run the motor at that RPM and measure the voltage produced. A motor run that way is essentially a generator. But I don't have access to a drill press with a known and verified RPM.
          • SteveReesor
            • Dec 2007
            • 24
            Try an prop with less pitch say an X442...or even an ABC 42x55.
            Increasing motor RPM by dropping a wind or two...drop down in pitch slightly to keep the RPM's up an let it wind out.
            Reesor Boat Works
            • Bill-SOCAL
              • Nov 2007
              • 1404
              I'll give that a try, although I am hard pressed to believe that a m445 was too much prop for it. It has that much less torque??
              I have a x442 I can try and a 42x55 and a 440/3, which I use on my SV - which is much smaller than this boat. I can also go all the way down to a x637 if I have to.
              • ReddyWatts
                • 1711
                Mount an airplane prop on the motor and get a laser prop tach for checking the RPM/KV difference of the motors. Maybe one of your buds has one you can borrow.
                ReddyWatts fleet photo
                • Eyekandyboats
                  • 1921
                  what was the condition of the motor before it went into the boat?
                  did you buy new or used, or ...
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • Jeepers
                    • May 2007
                    • 1973
                    Bill my P mono ran great on a X442 4s1p 9XL 45 to 50 mph.
                    • Bill-SOCAL
                      • Nov 2007
                      • 1404
                      In order:
                      I have plenty of props and a tach. Not sure it's worth that much work
                      Motor was brand new, never mounted or run
                      I'll give the smaller prop a try. Maybe I was expecting too much. Seems like a m445 should not be too much prop, but maybe it is.
                      I want the 9XL to be faster than the 10XL. If it takes a smaller prop to go faster, then I am OK with that.
                      Jeepers, which hull did you have??
                      • properchopper
                        • 6968
                        re :
                        Prop down ! You've seen my 9XL Titan rip, completely aired out with a X442 & not any faster with the modded M445 . Your boat , at 32.5 inches with the Delta-like hull runs waay wetter then the 29" Titan. Methinks the 9XL isn't unwinding !! My 2.3 cents anyway.
                        • Bill-SOCAL
                          • Nov 2007
                          • 1404
                          Like I said, I plan to go small. In this case maybe size does matter, but in the other direction. I thought your Titan had an 8XL?? Guess I thought wrong!!
                          • properchopper
                            • 6968
                            re :
                            Titan's got a 9XL/Hydra 240. Been in it over a year now & still pumpin'. Drifter's got the 8XL; much less running surface, OM 26 's got an
                            8XL for fun running [ & embarrasing nitro SV 27's ]
                            • domwilson
                              Moderator
                              • 4408
                              Yep a smaller prop might be your best bet. I have a 9XL in my 30" Skunkworks cat. With a X445 it was kind of slow. Maybe about 25 mph. Changed the prop, to a X637 and a X640. Big, I mean really big, difference. Beats my SV27 with a X642 on the same batteries. 4S1P lipos.
                              Government Moto:
