I have a UL -1 motor on a AC VS1 Tunnel. ESC is Seaking 120. I know AC ESC setting is 10* and the closest I have is 11.25*. All this is simple.
I am not looking for gains in speed. ( I am plenty happy with the speed), temp on the motor is non-issue as it is in open air and water is circulating thru.
ESC temp was also low at 110*, however the caps were at 160* !! Infact they were bulging a little and I spend the afternoon changing them. I know more timing may or may not increase RPM but can help with efficiency, may help keep the temp lower to a point. But I seem to recall most often here @ the Forum people are recommanding dialing back timing advance to help the motor to run cooler, my question is does lower timing help the ESC run cooler? And if so would the caps be cooler as well?
Running Skylipo 4s, 5000mah, 40C. ---I know battery can be an issue if the discharge rate is too low thus producing too much ripple current, I hope this is not the case as these batteries are in good condition and I run them on all my other 4s set ups.
