What causing this to happen
  • G-UNIT
    • 949
    When my impulse flips over it wants to keep running then stops then starts again, hard to catch with a fishing pole when it won't stop for awhile.
    leo 3674 2200. t180 on 4s.
    not a drop of water in it.
    no hands on the tx and even turned the trim down.
    any clues?
  • iridebikes247
    • Dec 2011
    • 1449
    do you think water is getting in the antenna hole? I have had boats flip over and get funny because water made its way into the plastic antenna rod.
    • siberianhusky
      • Dec 2009
      • 2187
      Failsafe lose it's setting?
      Sounds like the rx is losing bind then picking it up again, may be the antennae is going below water lever the floating up enough to rebind.
      My SV did something very similar, first electric, didn't know about the esc failsafe programming when I installed my Spektrum. fFipped, went to full throttle and stayed there until I got out there and picked it out of the water. Radio was on shore. As soon as the rx picked up signal it shut itself down.
      One antennae was taped under the deck, the other up a tube through the deck. 99% sure both were below water level when this happened to me.
      I set up the failsafe and no more run away motors.
      • G-UNIT
        • 949
        Dont see any water getting in any where, how do you reset the fail safe?
        • siberianhusky
          • Dec 2009
          • 2187
          Rebind the rx while the throttle is in the off position and everything plugged in. The rx is actually what holds the info. Make sure the end points and direction are correct then rebind. Not 100% positive if the esc has to be plugged in, might also work with a rx battery pack, never tried using one for power on a electric surface vehicle. Everything I run is 4s using the built in BEC.
          • G-UNIT
            • 949
            Ok I'll give it a try, Thank You all, and I'll post my results.
            • BHChieftain
              Fast Electric Addict
              • 1969
              Yeah, it sounds like failsafe is set to throttle on-- if the antenna is below the waterline it can lose the signal.
              Chief
              • Alexgar
                • Aug 2009
                • 3534
                Originally posted by BHChieftain
                Yeah, it sounds like failsafe is set to throttle on-- if the antenna is below the waterline it can loose the signal.
                Chief
                i agree
                had the same problem with a hobbking system where the failsafe was set to full throttle from the factory
                • Gary
                  • Jan 2009
                  • 1105
                  Or...............There is a loss of signal when the antenna is now faceing down in the water. This is most probable I would think. The reason it turns on and off is the sparatic signal it is getting and so she just does what it wants. Fail safe works when signal is "Lost" from what I understand, not sparatic.
                  H&M 1/8 Miss Bud 73 mph
                  Chris Craft 16 mph
                  • G-UNIT
                    • 949
                    By most replies it does seem to be the fail safe setting, as soon as I get off work I'll reset it and we'll know the next time it flips, hopefully it wont but I;m sure it will sooner or later.
                    Thanks for all your suggestions.
                    • Alexgar
                      • Aug 2009
                      • 3534
                      You can also check by turning off you tx
                      • G-UNIT
                        • 949
                        Ok, so I rebound the rx and reset the fail safe and it seems to be ok now, only rolled it once and the motor did not take off, righted the boat and it worked fine.
                        thanks all for your input.
                        • AlanD
                          • Feb 2013
                          • 54
                          G-unit, can you tell me the exact steps you took to remedy this? I have a thread going at http://forums.offshoreelectrics.com/...light=Failsafe with the same problem.
                          I've rebound the TX and yet when I power up the RX, the motor runs. I did have water in the antenna tube but radio box was dry after a flip. This is on a Blackjack29 with stock TX/RX and Hobbywing T180a ESC. Have not done the throttle calibration yet but wanted to see what steps you took.
                          • Darin Jordan
                            • 8335
                            Guys... if you are using the Spektrum radio gear, then once you get the boat all setup and perform all the calibration steps necessary to set throttle ranges, etc., then you should REBIND your TX to the RX. Once you do this, it will reset all of the failsafes to your NEW neutral points.
                            Darin E. Jordan - Renton, WA
                            • G-UNIT
                              • 949
                              Yes, I just rebound the system without holding the throttle or steering control, all neutral positions.
