Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Flex cable ????? - Offshore Electrics Forums
Flex cable ?????
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    Flex cable ?????
    Ok i finally got to run my DF33 the other day and just barley got to get it going till the flex shaft fell out and went to the bottom my question is i did not solder the cable and i did have the coupler tight but it still came out is there something else i can or need to do to make it grip the flex better?
    Im Only Responsible For What I Say Not For What You Understand
  • sanyijr
    • 376
    MAMBA,
    It slipped off the collet? So you lost the whole flex and prop? You either did not have it tight enough....or wrong size collet for flex cable....
    What sizes do you have for each? Which type collet?
    Sean
    • MAMBA2200
      • Jul 2012
      • 1202
      it was a .187 cable and collet that was purchased from here OSE and i had it really tight and yes i lost shaft bushing prop and bullet nut
        • 7673
        I have had to relieve the slots in a couple of my collets so they would tighten down.Should be in my "Little Twin G" Thread buddy.
        • MAMBA2200
          • Jul 2012
          • 1202
          OK I will look at it thanks
          Sent from my FE Phone
            You need to lubricate the threads and bearing surfaces of any collet to get the maximum grip. Otherwise too much wrench force is wasted overcoming internal friction within the collet. Use Neverseeze or a similar thread product. Then you won't need to tighten the collet so much yet still will have maximum grip.
            • tlandauer
              • 5666
              Some use this between the stufing tube and the collet.http://www3.towerhobbies.com/cgi-bin...?&I=LXD835&P=7
              Also a trick I learned here from Fluid is to use anti seizing compound for the threads of the collet, it will allow you to smoothly tighten the collet without galling. Any auto store sells them.
              • iridebikes247
                • Dec 2011
                • 1449
                I usually solder the end I know you said you haven't done this but it definitely makes a difference and eliminates any slip problems.
                • jcald2000
                  • May 2008
                  • 774
                  Amen!!!
