what does everyone use for Epoxy when building??
  • bikergreen
    • Jul 2012
    • 422
    Just wonder what people like to use - Is the 30min Z-poxy the right one for gluing down motor mounts etc when building? What I used on my last build works fine but its not clear..
    Thanks
  • tlandauer
    • 5666
    Thanks
    30 min. Epoxy all the way, the slower cure the stronger in the long run, there was a thread recently explained this thoroughly, do a search.
    When you said "not clear" do you mean cured the Epoxy not clear or you are not clear which epoxy to use? I ask because if you use 30 min. Z-Poxy, the resin is not a clear formular, as opposed to their brownish but clear Finishing Epoxy ( 30 min. ) . I now use West System 205/206, it is clear as crystal. But this is not important. HERE IS THE LINK/DISSCUSION:http://forums.offshoreelectrics.com/...-Slow-Hardener
    Cheers!
    • Rocstar
      Joel Mertz
      • Jun 2012
      • 1509
      West System G/Flex works well and comes in 4oz bottles and mix 50/50.
      • longballlumber
        • 3132
        Just an FYI, West Systems hardners will bronze or red-en over time. The older they get the more the color will change. Don't be alarmed, the changing of color it will cure just fine. I have some hardners that are several 4+ years old that are red-ish in color but still cure fine...
        Later,
        Mike
        • tlandauer
          • 5666
          Later,
          Mike
          Thanks Mike, for the heads up. I am relatively new to all this, so the reason why I haven't observed any color change, but it is really good for me to know this.
          • iridebikes247
            • Dec 2011
            • 1449
            I also use West Systems epoxy. They have a ton of additives available so one can epoxy an area then sand it, or use microfiller to bulk up an area. Really good stuff and takes awhile to dry.
            • JimClark
              • 5907
              System 3
              Billy Graham
              • bikergreen
                • Jul 2012
                • 422
                Thanks guys - I do search but skipped that step this time for what ever reason. Just looking to find a better epoxy for next time.
                • Richie the shipwright
                  boatbuilder
                  • Dec 2012
                  • 185
                  Best ive ever used was a brand called "SP systems" although im not sure if its still available.
                  All the epoxies ive ever used discolour over time. West have a 207 slow cure hardener that is designed to give best results when coating and sheathing wood. :-)
                  Im confused..... no...wait...mabee im not?
                  • T.S.Davis
                    • 6221
                    West systems. Worth the premium I pay for it too.
                    I use all three hardners too. Fast, slow, and special clear.
                    Noisy person
                    • longballlumber
                      • 3132
                      Ha! I think it's safe to say that I've made you a believer!
                      Later,
                      Ball
                      • T.S.Davis
                        • 6221
                        Yes sir. That would be your fault.
                        Noisy person
                        • jcald2000
                          • May 2008
                          • 774
                          I have used US Composites for years vacuum molding my boats, with fast and medium hardners. Do not use Slow hardner unless you want to post cure at 120 degrees for 12 hours.
                          Wholesale/retail sales of composite and fiberglass materials, including epoxy, adhesives, carbon fibers, urethane foam, urethane casting rubbers
                          • T.S.Davis
                            • 6221
                            I did too Jim. My first Whip 40 was all US Composite. Now I'm spoiled.
                            Noisy person
                              boatbuilder
                              • Dec 2012
                              • 185
                              Man that threw me!! Sounded superhot until i realized you meant 120°f . (We use °celcius down under.) I've got that sort of heat happening in my shed at the moment WITHOUT AN OVEN!! No kidding...45°C in there today.... saw 52°C last week... Phew!!
