Stinger Question
  • majorpat
    • Nov 2012
    • 120
    Stinger Question
    Hi, I have a prop shaft that comes directly through the transom no tube under the boat etc. and the tube has two ball joint turnbuckle type parts that fit one on each side to keep the shaft alligned. Well one of those turnbuckles came of and was lost. I did not build the boat and thusfar have been unable to locate the replacement parts. Can anyone help me find the manufacture of the turnbuckle defices as I looke dat the vendors I know of with no luck.
  • h2o 1
    • Sep 2011
    • 770
    If you could post a pic of ur setup.someone will likely know what hardware ur using and maybe you can find parts in the swap shop
    • majorpat
      • Nov 2012
      • 120
      I am new to this site and not very tech literate. I have a picture on my I-Phone but do not know how to post it here. Could you help me?
      • h2o 1
        • Sep 2011
        • 770
        I know nothing about I phones! If can email me a pic,i will post it for you. Pm;ed you my email addy. we'll get it one way or the other!
        • h2o 1
          • Sep 2011
          • 770
          For Majorpat! Guys,this is his Hardware.
          • egneg
            • 4670
            He wants a U-joint not a turn buckle. Need to know shaft Diameters to help.
            IMPBA 20481S D-12
            • h2o 1
              • Sep 2011
              • 770
              Reread his post! Turnbuckle lost!!! Im just uploading his pics guy!
              • egneg
                • 4670
                My question is still the same one.
                IMPBA 20481S D-12
                • lenny
                  • Sep 2010
                  • 4294
                  That looks like a real PITA to setup.
                  ? ONLY IF THEY WORK
                  • h2o 1
                    • Sep 2011
                    • 770
                    More of Majorpats setup.
                    • devo
                      • Aug 2012
                      • 146
                      Those are just standard rc car turn buckles
                      • mtbenjamin77
                        • 761
                        The only manuf. I know that makes anyhting like that is MHZ-USA. It looks similar to a trimax. Looks like you need one of the transom mounts and the turnbuckle with ball joints
                        • majorpat
                          • Nov 2012
                          • 120
                          Bump
                          • lenny
                            • Sep 2010
                            • 4294
                            Have any pictures of the setup inside of the hull ?
                            It may be cheaper and better to just put a standard stinger on it.
                            Did you ever get to run the boat, If so how did it handle and run ?
                            ? ONLY IF THEY WORK
                            • majorpat
                              • Nov 2012
                              • 120
                              The setup on the inside is just a bolt through the transom to the hardware on the outside. I do not have any pictures of the inside. I have run the boat many times and it runs very well and handles just great. I really want to find a replacement part to return to the original design as it ran so well and handled so great.
                              Thanks for the input
