What size ??
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    What size ??
    So as per the ose site i ordered a. 187 teflon tube and the site said i needed a 9/32 brass tube so that is what i ordered but the teflon liner will not fit in the brass do i need a 1/4 brass tube???
    Sent from my DROID RAZR using Tapatalk 2
    Im Only Responsible For What I Say Not For What You Understand
  • Rumdog
    • 6453
    I NEVER run Teflon. It's pointless. 1/4" tube with no liner for .187" cable.
    • MAMBA2200
      • Jul 2012
      • 1202
      Does it need to have allot of room without the liner cause the 9/32 tube is way bigger without the liner it has good tolerance in a 3/16 tube??
      • h2o 1
        • Sep 2011
        • 770
        Ordered the same ones Mamba! Just stretch the teflon tubing,it will then slide right in and it will shrink back to normal inside the brass tubing
        • MAMBA2200
          • Jul 2012
          • 1202
          Just pull it to stretch?
          • h2o 1
            • Sep 2011
            • 770
            YEP! it makes the teflon tubing longer and thinner,stretch it just enough to fit inside the brass,slide it in,wait a few days for it to shrink to it orginal diam and cut to length
            • Southwest
              • Sep 2012
              • 274
              When i get .130 cable and liner, i have to SAND the liner some so it slides in with a small nudge. OSE has a table showing with/without liner and correct sizes to use.
              • MAMBA2200
                • Jul 2012
                • 1202
                Ok will give that a try thanks
                • h2o 1
                  • Sep 2011
                  • 770
                  Your welcome! Remember,just enough to get it in!
                  • MAMBA2200
                    • Jul 2012
                    • 1202
                    Thanks h2o that worked perfect
                    • h2o 1
                      • Sep 2011
                      • 770
                      Good deal!! Dont worry if its a little loose,it will shrink very tight inside the brass!
