Rudder assembly???
  • straitline
    • Dec 2012
    • 158
    Rudder assembly???
    Building a DF35 and wanted to know what rudder to use. I'd like to get at least a 4" set back with a dual water pickup. Or what would you use??? Again I need the help from OSE. This has been the most reliable source yet.
    Thanks
  • h2o 1
    • Sep 2011
    • 770
    Hi,im building this same hull. Im using Speedmaster hardware and trim tabs and OSE turn fins.The Speedmaster 60 from OSE is the rudder im using.Regardless of whatever rudder you use you will likely have to grind ur trim tabs abit to get everything to fit. As you can tell on your hull space is very limited.
    • straitline
      • Dec 2012
      • 158
      Can you give me the exact part number? And thanks for the reply!
      • h2o 1
        • Sep 2011
        • 770
        http://www.offshoreelectrics.com/pro...s-rud-dual-tap
        • h2o 1
          • Sep 2011
          • 770
          Here's a pic of what it all looks like together.
          • straitline
            • Dec 2012
            • 158
            Thank you!
            • h2o 1
              • Sep 2011
              • 770
              Your welcome! Good luck with ur build!
