Esc suggestions
  • SpeedFreak_86
    • Jun 2011
    • 182
    Esc suggestions
    I'm running a Leo 3674 2200kv motor on 4s, I need a small powerful esc bc space is very very limited. What do you suggest?
    Slow and steady isn't my pace
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    T120
    • jkr
      FE Addiction
      • 568
      Originally posted by Heaving Earth
      T120
      And timing @3,75
      • SpeedFreak_86
        • Jun 2011
        • 182
        Is the avalible on ose?
        • h2o 1
          • Sep 2011
          • 770
          What type of hull,hydro,mono,cat?? Whats the lenght? Mono hulls will draw more amps than cats or hydro's due to more surface area in the water.
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            Maybe, or kintec, or hobbypartZ sometimes has them cheaper than both.
            • Basstronics
              • Jun 2008
              • 2345
              http://www.offshoreelectrics.com/pro...er-seaking-120
              • TristanJones
                • Oct 2012
                • 266
                http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
                Ive run one of these before, they are good, just be sure to make sure the barb fittings for the water lines are held in and sealed with loctite.
                Any more than 4s will kill the BEC eventually. (mine did anyway)
                • lenny
                  • Sep 2010
                  • 4294
                  Free shipping.
                  ? ONLY IF THEY WORK
                  • martin
                    • 2887
                    The T120 & Seaking 120 are the same esc.
                    • SpeedFreak_86
                      • Jun 2011
                      • 182
                      It's a tunnel hull, thanks for all the links!
                      • martin
                        • 2887
                        You also need to watch things with a 120a esc with that motor, theirs not much headroom. You have to watch run times & prop sizes personally id go with a higher amp esc.
                        • lenny
                          • Sep 2010
                          • 4294
                          Just add some caps,
                          I have been running one in my 36" Pro boat shockwave.
                          T120a with 0ne added cap and a 4074 2200kv on 4s with a x646/3 prop and gps at 45mph and nice run times,
                          Also run nice and cool.
                          ? ONLY IF THEY WORK
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            I use seaking 120 in a 29" deep v with 3674 Leo 1700kv on 5s2p with x444 prop. It's a wide heavy boat and I have no problems with esc for two years now....
                            • Heaving Earth
                              Banned
                              • Jun 2012
                              • 1877
                              Just my experience tho
