Handling issue on pursuit.
  • tlandauer
    • 5666
    On mine, the lower hole on the blade pivoting block is elongated for kick-back protection, can you file the hole the other way so you can tug the rudder in just a bit?
    Just thinking out loud tho, don't know if yours is like mine. Mine does look like every other Pursuit from the pics tho.
    Sent from my Droid using Tapatalk 2
    • lenny
      • Sep 2010
      • 4294
      Hears mine, And what I am talking about to do.
      You need to do the top hole on mine because of the edge on the rudder,
      That lays on the rudder bracket.
      ? ONLY IF THEY WORK
      • Southwest
        • Sep 2012
        • 274
        Bases are covered.
        • stadiumyamaha
          • 1284
          Mines like yours Lenny. I'm going to elongate the top hole so I can pivot it to a more positive angle. ImageUploadedByTapatalk1359868205.501969.jpg
          white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
          • lenny
            • Sep 2010
            • 4294
            Cool,
            Check those turn fins to.
            And one step at a time.
            ? ONLY IF THEY WORK
            • tlandauer
              • 5666
              Lenny: You are Brilliant!
              I should have kept my mouth ( hand) shut , mine is just like it but I was sitting back stage before a concert and reading this thread tonight and can't resist to BS ,
              I clearly didn't remember how the rudder is assembled, my bad, sorry guys!
              • siberianhusky
                • Dec 2009
                • 2187
                Try a couple washers under the top or bottom of the rudder mount to see if it fixes the problem before breaking out the heavy machinery.
                One of mine has a small wooden wedge under the rudder mount, angled transom couldn't get the caster right, it's actually an H&M cat.
                • stadiumyamaha
                  • 1284
                  #23
                  Lenny, my fins ate in a good place, its either a rudder problem or a cog problem. Mine is set up a little differently than most. I'm going to run it today and feet back with y'all.
                  • stadiumyamaha
                    • 1284
                    #24
                    Shoot me a pic of y'all's find if you have a chance anyway.
                    • lenny
                      • Sep 2010
                      • 4294
                      #25
                      ? ONLY IF THEY WORK
                      • lenny
                        • Sep 2010
                        • 4294
                        #26
                        I just looked at mine at the time and thought I need to try this on mine,
                        This thing was setup so wet, And with the motor bearing noise it had.
                        It has a 4074 1800kv in it now and I need to start tweaking the boat to get it to ride good.
                        I still need to find bearing for both motors I got with it and fix the rotors.
                        It's all good,
                        Just your new name is Dr. Timothy Leary.
                        ? ONLY IF THEY WORK
                        • stadiumyamaha
                          • 1284
                          #27
                          Heading to the pond. Ill let you know how it runs with the rudder mod. ImageUploadedByTapatalk1359913814.638178.jpg
                          • lenny
                            • Sep 2010
                            • 4294
                            #28
                            Can you get some video ?
                            ? ONLY IF THEY WORK
                            • stadiumyamaha
                              • 1284
                              #29
                              Ill try. Only have a iPhone with me.
                              • lenny
                                • Sep 2010
                                • 4294
                                #30
                                May be you can rig it to your tx and aim the tx at the boat like a gun,
                                I use velcro straps to hold mine camcorder on to the tx.
                                I was using this camera, But have a new one now.
                                ? ONLY IF THEY WORK
