Is this a BBY oval master?
  • arnie84
    • 236
    I picked this up awhile back from a package deal and I believe it is a oval master? It has .150 flex shaft with 3/16 prop shaft. Plastic Prop says 48 on it. I know She needs some TLC & was thinking about 1700 kv sv27 blue motor and 45amp aquacraft esc on 4s 2 2s packs? Also would it help too put a thin layer of fiberglass on bottom inside hull to stiffin it up a bit since stuffing tube has bin riped out anyway? is the hardwear correct for the hull?
    Looks like the Phantom 8 to me.
    • arnie84
      • 236
      Wow yes it does & it has turn fins do u know the difference between the two? I can measure too tell maybe?
      • Namba328
        Factory Team Pilot SPP
        • Jul 2011
        • 1117
        arnie just pm Randy at BBY. he could tell you for sure. One thing i know of is the bottom is totally different and the ovalmaster is smaller. But that phantom would be a fast hull.
        Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
        Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
        • Namba328
          • Jul 2011
          • 1117
          http://forums.offshoreelectrics.com/...-22&highlight=
          Here's what mine used to look like before my bec quit in my esc when i ran it for the first time on 4s .
            The OvalMaster came in three sizes, 21", 26" and 29". The Phantom is 24" long. The hardware on the OP's boat is of better quality than the photos. The boat would be great for 2S power, or Limited 4S. Too much power though and it won't stay on the water.
            • RandyatBBY
              • Sep 2007
              • 3915
              Jay does know my boats on this one. It is a Phantom 8 a great little boat. It was designed for 8 cells NiMH. It will work great on 2S and a RC Car motor or a little bigger motor and larger three blade prop.
              Randy
              BBY Racing
              • arnie84
                • 236
                ok thnx I have tons of 17.5 motors just need too find a water proof sensored esc. a 3 blad prop like a x437?
                • JohnZ
                  • May 2010
                  • 254
                  What is a 17.5 motor? What would be an equivalent brushless?
                  • arnie84
                    • 236
                    17.5 is a sensored offroad motor range from 1900kv too 2200kv some have less kv more torque and some higher rpm less torque but it all equals out with gearing and boost/timming in offroad in the end. They r 36mm by 52mm long. Problem is most have fins or slots for cooling so not sure on watercooling type too use maybe coils like traxxas blast and u would need a sensored waterproff esc and the tekin rs is not waterproof. When u add timing/boost or turbo like the Tekin has it really adds tons of top end
                    • JohnZ
                      • May 2010
                      • 254
                      Okay, I now see why the UL-1 motor is so popular : its size and performance is similar to this motor. A Leo 36-50 motor of the same KV would be another choice then.
                      • arnie84
                        • 236
                        The ul1 2030 motor is popular for boats due too haveing 6 poles which adds torque. The tekin is a 2 pole motor. higher pole motors would cause too much wheel spin for offroad. Im stilling learing myself, but I have bin racing & tunning offroad motors since the brushed motor days.
                        • RandyatBBY
                          • Sep 2007
                          • 3915
                          My dad always said "That when you quit learning you are dead or at least brain dead"
                          Randy
                          BBY Racing
                          • JohnZ
                            • May 2010
                            • 254
                            Obviously, there are a lot of dead Americans still wandering the streets.
