Anybody have a trick for removing a stripped set screw on a collet? Thanks
Stripped set screw
I've been able to drill them out with a good split point drill. Collet may be ruined afterword though.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1 -
good point iamandrew, I had to drill one out once and filled a t600 outrunner with metal shavings. Took quite awhile using masking tape and putty to remove it from the motor.Comment
A left hand drill bit will sometimes back it right out.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
Good tip sundog.....I bet a sharpthreaded screw held in a drill on reverse...might grab it and back it out too. There is also some 19.95 for a limited time only!!! late night tv infomercial thing that is designed to remove stripped anythings.Comment
I have a set of this: http://www.amazon.com/Alden-4507P-Gr.../dp/B000Q60UOO I have sucessfully removed set screw from pinion gear in my 1/10 electric buggy with this, it takes a bit to figure out which diameter to use (set screw was 1.5mm dia.)
This box has four different sizes but the smallest ( #1) should work. They are simply labeled as #1, 2, 3, 4, no specific diameters labeled.Too many boats, not enough time...Comment
