Ready for a mainden run
  • kevinlew211
    • Aug 2008
    • 586
    My new project after 2 years ( thanks to Jeff)
    Herzog Hurricane 45" mono
    Lehner 3080/7
    Schulze xl 40/161wk
    Hyperion 10s2p
    ....and alot of goodies
    Its ready for a mainden run with my HOTMBC club in the next meeting
    NOW...time for me to clean up the garage before my mom she will notice
    Also a pic of one of my older HPR115, I miss her
  • lenny
    • Sep 2010
    • 4294
    Hey looking good,
    Good luck with that baby.
    Is that transom very thick ?
    Just because, That rudder bracket is going to put a lot of torque on it.
    How long is that thing ?
    ? ONLY IF THEY WORK
    • kevinlew211
      • Aug 2008
      • 586
      I use 6" bracket, the transom wood is really thick Lenny, its thicker than any boat I worked on before like Sniper and DF, to the point, I have to use epoxy instead no more space for nut to secure the water outlet. =)
      • lenny
        • Sep 2010
        • 4294
        Nice and thick than,
        Why so long of a bracket ?
        Won't it put the rudder in the thrust cone of the prop more ?
        ? ONLY IF THEY WORK
        • kevinlew211
          • Aug 2008
          • 586
          Lenny, hopefully I can get tighter turn with less rudder angle, I was affraid about messing thrust cone too so I got my 4" bracket ready =)
          • lenny
            • Sep 2010
            • 4294
            Ok, But no hairpin turns for that big baby.
            I think the 4"will do the job better and look a lot better to,
            Also less stress on the transom to.
            When are you going to run it, Tomorrow ?
            Hey, Where that cat come from.
            Looks great.
            ? ONLY IF THEY WORK
            • kevinlew211
              • Aug 2008
              • 586
              Looks great.
              Its one of my 1st scale project, HPR115, and here my older HPR135, its now belong to a lovely Australian , I miss them both....
              • TheShaughnessy
                • 1431
                I'm far from a guru but I like my rudder to be fairly close to in line with the prop, not behind it but beside it. Would be interesting to hear back after you try both standoffs : 4 and 6 inch
                • lenny
                  • Sep 2010
                  • 4294
                  WOW !
                  ? ONLY IF THEY WORK
                  • kevinlew211
                    • Aug 2008
                    • 586
                    This is my 1st time trying too, I will let you know the dis/advance of it, I copied this setup from Jeff's gas boat and I like the way his boat running, hopefully its work with mine too =)
                    • kevinlew211
                      • Aug 2008
                      • 586
                      WOW !
                      Sorry Lenny, I'm a perfectionism =)))jk
                      • kevinpratt823
                        • Aug 2012
                        • 1361
                        Gorgeous boats! Looking forward to vid of the mono if you get some! You said 10s2p, but I only see 2 packs, are they 10s packs or are there 2 more hidden in there? Racemechanix ran a 6" rudder on his Sniper 45, I am building one as well, but decided to go with the 4", and have the 6" to try as well. I'm definitely curious to hear about the charecteristics between the two.
                        My private off road rc track
                        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                        • jkr
                          FE Addiction
                          • 568
                          Who sells them?
                          • siberianhusky
                            • Dec 2009
                            • 2187
                            Beautiful boat! Best of luck on the maiden voyage. Still a few months until liquid water around here, can't wait to get my new projects on the water.
                            About this time every winter I start questioning leaving Texas!
                            • Chilli
                              • Jan 2008
                              • 3070
                              Originally posted by jkr
                              Who sells them?
                              Lenny, Allot of gas guys like 6 inch rudder extension. Personally I think they are overcompensating for something....
                              Seriously, Kevin's hardware set up is a typical gas set up with a 6" rudder extension and 2.5" offset. The Hurricane is a well built boat and transom can take the long extension, no problem. John Finch told me a longer rudder extension helps keep the bow down in the turns which probably helps in race water. My old gas Sniper could turn on a dime with a 4" extension but the hull wasnt the best in race chop so I changed over to a Aeromarine Vector before I had a chance to try a 6" extension.
                              Nice Job Kevin. Good luck with the maiden!!
                              Mike Chirillo
                              www.capitolrcmodelboats.com
